Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
My DVD RECORDER MODEL NO DMR-EX75EB, THE CODE U81 KEEPS COMING UP WHEN I SWITCH ON MY RECORDER, ALSO I CANNOT GET INTO MY SETTINGS TO SEE IF I CAN FIX IT. THANK YOU
  • Panasonic Master
  • 508 Answers
This seems to be a common fault with many Panasonic DVD recorders of the DMR-EX series.
This is one of several error codes generated by the main microprocessor IC in the unit which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used (if available) and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
I posted this 'advice' for this (and a couple of similar models) previously. The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Because of the malfunction, the user settings and options are inaccessible, and there is no official user-reset option on this or any model of the series to clear this particular error.
Certainly worth investigating at least, as Panasonic usually make great products.
It's up to you as to what you decide to do from here.
Posted on Mar 28, 2011
What does U81 mean
It could mean there is a fault on one of the circuit boards. See
http://www.avforums.com/threads/panasonic-dmr-ex75-85-u81-error-repaired-solved.1486954/
Aug 25, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Fault A2
Are you SURE it's a fault code, and not the selected AV input? (A1, A2 or A3?
Press the Input Select button on the remote to cycle between AV inputs and Freeview channels
Jun 22, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
U81 is permanently on the screen, I cant get the TV listing menu, nor can I get it to record, can you help?
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter'.
This error can be caused by a number of different reasons but one of the most common is a software / firmware problem relating to the Freeview part of the unit.
If you turn the unit off for 30 minutes it should reset the fault.
At this point to need to check what version of firmware you have installed and then check the Panasonic website for your country for the latest version.
Jul 02, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
U81 error up Do I have to take it to a electrical repairer or is there anything i can do ?
I posted a suggestion a couple of months ago about a similar Panasonic DVD recorder (model DMR-EX78EB) with this exact problem:
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
The U81 and U80 codes don't mean anything in particular because the corruption error(s) could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error codes' in any device.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
Certainly worth investigating at least; and you should not need to purchase a new unit. Go with the quote first - then decide on a further course of action.
May 24, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Error code U81 onDMR-EX75EB Unit will not power up, keeps shutting down
I have posted advice on the possible cause behind this error code (as well as other members on FixYa) for this model DVD recorder previously. For you I will re-iterate:
The U81 error code is a common problem
(sometimes unplugging the unit from the power point for up to 30 minutes, then reconnecting resets it completely and clears the error code with no further remedial action required)
Usually when this error occurs, and persists, the unit cannot be reset by the user. In your case, the constant shutdown may also likely be a fault in the switchmode power supply as well as a problem with the microprocessor. It may or may not prove an expensive exercise.
Certainly worth investigating at least.
I hope I have shed some light on the subject for you and similar people who have experienced this particular error display.
Apr 03, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD recorder DMR-EX78EB - Keeps showinf error message 'U81' on display. This means that it does not perform set recordings. What causes this please and how can we fix it as I am fed up with finding...
I posted this 'advice' for this (and a similar) model previously. The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Mar 24, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
My DMR EX75EB it fails to operate and a code of U81 comes up.
The U81 and U80 codes don't mean anything in particular because the corruption error could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
I posted this 'advice' for this model previously. The DMR-EX75 and DMR-EX85 are prone to U81 - which is a common error code.
Mar 14, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
My panasonic remote won't work. the lcd on the dvd shows set 1 everytime I click on it
I have had this happen nore than once. If you press the 1 button and hold it down. At same time press and hold the enter button for 2 or more seconds. Your remote will now be set to the system. Some models have a device code of 2 or 3. If your not sure what your device code is start with #1 device code.
Oct 13, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Playing HD Video
This machine won't play HD-DVD. What it Will do is to play standard discs and upconvert them to your HDMI format...accordianman
Jan 06, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
917 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
