Question about Toshiba Computers & Internet
Toshiba satalite A200 PSAF0A-0YK01C. After restoring to out of the box condition with no positive results, I wiped the hard drive and replaced windows vista. All seems to work well until randomly the screen scrambles and the only way to get it back to normal is to switch off and restart. The battry is removed and only running on AC power. I'm no boffin and have struggled to get this far so any real help with be gratefuly recieved. the machine is only 3 yrs old, I can only suspect at this point its going to be a costly repair?
SOURCE: Toshiba Satellite L25-S119 No boot
Had the same problem turned out to be the DVD drive. Apparently it won't boot if the DVD drive is not recorgnized.
Posted on Feb 21, 2008
mdsaeed67
  • 849 Answers
SOURCE: Toshiba Sat A135-S2386 System recovery downloads??
i guess that the computer has installed vista ultimate and the creation of recovery cd option has gone with it. the new recovery cd will solve all your problems.
Posted on Nov 27, 2008
Geekman
  • 32281 Answers
SOURCE: toshiba a200 laptop Have black screen even tho
You could have a defective screen - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 19, 2009
  • 159 Answers
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Posted on Oct 29, 2009
RescueTechLA
  • 2653 Answers
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Posted on Apr 04, 2010
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
Factory reset default my notebook
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.
6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
May 05, 2013 | Toshiba NB505N500BL 1 GB Hard Drive
Reset password, recover back to factory restore point
your notebook.
5. Select Recover to out-of-box state. 6. Click Next again.
Dec 02, 2012 | Toshiba Satellite C655-S5132 Laptop...
How do I do a complete restore on a Toshiba Satellite A75-S209
your notebook.
Aug 21, 2012 | Toshiba Satellite A75-S209 Notebook
Toshiba restore
your notebook.
Aug 19, 2012 | Toshiba Computers & Internet
Re-formatted drive boot mananger missing
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Aug 04, 2012 | Toshiba Satellite Computers & Internet
Toshiba l645 bootstrap
The Windows operating sustem appears to be corrupted and most like to get a working computer you need to restore it back to the factore default condition.
Before you attemp to do this and to back up data, remove the hard disk from the Toshiba and connect this hard disk to an USB hard drive adapter, then plug this adapter into the USB port of a working computer. This computer will see this as an external storage device. You can then open the various folders on this drive and back up your data on this computer or an USB memory stick.
To restore your Toshiba, insert the hard disk back into the Toshiba and follow these instructions..
your notebook.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 05, 2012 | Toshiba Satellite L645DS4037 Notebook PC
I have a Toshiba Satillte L505-S5971 Got something
Your original hard disk may have a recovery partition on it. You may be able to restore the Toshiba to Out of the Box condition, but it will wipe out your data so bach up your data first. For instruction to restore your Toshiba, click on this link and follow my instructions :-
Feb 14, 2011 | Toshiba Computers & Internet
How do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Feb 25, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Wiping the hard drive
i presume you have not formatted the drive yet. first make sure there is a restore partition on the drive.... after that go into the start menu and look for a menu item called restore or restore tools .... i'm not 100 % familiar with that computer but the basics of restoring the system are generic.
Robert
Dec 16, 2008 | Toshiba Satellite M40-S417TD Notebook
Computers & Internet Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
