Question about PNY 4GB Secure Digital High Capacity Memory Card
How do i remove write protection from a memory card 4GB cant delete files or move files,if i want to format it says remove the write protection
  • 42 Answers
+look if your lock switch on the memory card is in ON position generally this is the case if it is ON then switch it OFF and try moving the files to or from the memory card
if you are happy with my solution please rate me high and vote for me
Posted on Mar 28, 2011
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
When i inserted 4GB pendrive in the pc when i open the pendrive it doesn't open and shows write protection and it can't be formatted at this situation.
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected memory stick
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Write protected
write protected i am not able to copy nor delete files from my 4gb transcend memory card
Apr 17, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I cant format my transcend 2 gb pen drive it says write protected
do you see any switches on the side of it ? if so move it to the other position and try again.
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected memory card..sd card
There should be a little switch on your memory card reader, if it is facing down, your card is locked. Push it up and then you should be ready to go. :)
Jul 07, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
PNY 4GB Secure Digital High Capacity Memory Card Logo
83 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
