SOURCE: ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
SOURCE: KXTC1040CD cordless phone and answering machine
I have same problem, started 3 days ago. I could not figure it out. I checked the user manual and there was no info on this error message.
SOURCE: GE duo 21828 cordless telephone english user manual
Press down key until the handset menu appears and press "INT/OK" key
Press up or down arrow key to select the submenu "Resgister" and press "INT/OK" key
Handset display shows "SEARCHING".
Press and hold "page" key on the base station more than 4 seconds until acknowledgment signal is heard
Enter the PIN (default setting = 0000) and press "INT/OK" key
on the Handset
If the input PIN is correct the registration procedure will be completed with a confirm tone.
After a connection is established the name and number of the handset appear in the display
Note : The base will be ready for registration for 10 minutes when the page key is pressed and held for more than 4 seconds.
Please let me know how these phones have performed, are you happy with them. Thanks
SOURCE: i have philips cd245 duo
can you give me the exact model number
CD2451B for example. check the back, bottom etc.
SOURCE: Manual for Philips CD130 DUO missing
I am not 100% sure that this is the model you are looking for, but I found a manual on the UK page of Philips:
http://www.p4c.philips.com/files/c/cd1301s_05/cd1301s_05_dfu_eng.pdf
Have a look and let me know if that helped you!
Although it might not be the exact same model, it might have the information you are looking for.
The complete list can be found here.
