How do I get the old unit off the wall? - Heating & Cooling
  • david94160 Mar 28, 2011
    It is a wall control unit for a gas central heating system with the only name on it being - Drayton Tempus-seven. There being no other info or model number. Thanks, David
  • 17,970 Answers
There are various types of heating units used in homes today. The wall heater is a supplemental heating unit. It is used to heat a small area and is usually installed in the bathroom, laundry room or bedroom. A wall heater is mounted into the wall or on the surface of the wall and uses a fan to distribute warm air throughout the room. The air is warmed by a row of heating elements within the wall heater. These elements and the fan are controlled by a thermostat so as to maintain a preset temperature within the room. Check this generic instructional:
1. Measure the dimensions of your current heater. Use these dimensions to purchase the replacement heater. Similar dimensions will reduce the amount of work needed to replace the old wall heater, especially if your heater is mounted in the wall as opposed to on the surface of the wall.
2. Unplug the heater and let it cool completely. Unscrew the fastening screws that hold the wall heater to the back plate. Gently remove the wall heater from its mount and set it aside.
3. Read the user's manual of the replacement heater to ensure that any special requirements are met. Connect the heater to the back plate by mounting it on the back plate and fastening the screws that came with the heater.
4. Plug the heater in and turn it on to test if it is working.
Also, in this link could find Instructions/Tempus7Instr (pdf)
Hope helps.
Posted on Mar 28, 2011
  • 6,993 Answers
please what's the name and model of the unit that you want to get off the wall. I need to know this for proper direction.
I hope you to get a reply from you soon.
Bye for now.
I have a two year old Redstone 30,000 BTU propane wall heater. There is a lot of dust behind the unit. After running for awhile on the 2 setting, it shuts down and the pilot is extinguished.
If it is a wall unit, it has an over temp safety switch which is most likely tripping from dust preventing proper airflow across it . A good cleaning should cure this.
Feb 04, 2015 | Heating & Cooling
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
Replacement of window unit
Yes,you can,they are basically the same,you can get a 18000 btu to go in it.The more the btu`s,the higher they are anyhow.
Jul 22, 2010 | Heating & Cooling
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Sep 30, 2009 | Hoover Dryers
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
Door opner stops/appears to lose power
How old is your unit. I need to know this it sounds like a Circuit Board problem. but would have to know how old your unit is.
Apr 13, 2009 | liftmaster Chamberlain Garage Door Opener...
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Ge wall unit cools and then stops
Weather below 50 deg F can harm airconditioners if you run them. If the unit is turned off, then the weather can get as cold as it wants to and not damage the unit. Also 99.999% of the time repair costs on wall units surpass the cost of replacing the unit. This is even accounting for the fact that you will have to pay $25 to $50 to get rid of the old a/c. 5 yrs isn't that bad for a wall shaker anymore. Suggest looking for a new unit.
Jun 27, 2008 | GE AJCQ08ACB Air Conditioner
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
