Question about Karcher FactoryReconditioned 1750 PSI 15 GPM Electric Pressure Washer K
How to replace fuse in kew dynamic 4000 pressure washer
My kew dynamic 4360 power washer stops and starts
possibly a blocked lance jet, does the spray pattern of the jet look good, a nice fan?
Nov 30, 2014 | All-Power America Garden
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Mar 28, 2010 | Garden
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Water pouring out of the pump on my kew powerwash
Hi, You can get this seal set for a 1502v from nilfisk alto or any alto dealer.
Dec 27, 2009 | Garden
Kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Sep 29, 2009 | Garden
Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Aug 14, 2009 | Garden
ALTO FORCE KEW COLD WATER POWER PRESSURE MACHINE STOPPED
Hi FRANK,
The answer of "Firehead" is correct. You have a start/stop valve with springs (springs = maybe broken by the rust). Kew sells a kit to repair. If you want i'll send a diagram to you.
JJ (Brussels)
Jul 04, 2009 | Garden
Karcher FactoryReconditioned 1750 PSI 15 GPM Electric Pressure Washer K Logo
508 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
