Question about Philips GoGear HDD6330 MP3 Player
Go Gear is not recognized by computer
I have re-installed from the beginning and used the device manager (which says it is not connected, when it is) and have downloaded all upgrades. The device is not damaged.
It went wonlky when trying to synch with Win Media Player 11 (it worked fine with 10)...it seems to be in a constant state of synching without the computer recognizing it.
Please help!
masterthemouth@yahoo.com
  • 8,596 Answers
You must roll back to WMP 10 - this device is completely incompatible with WMP11 - instructions are on both the Philips and Microsoft websites
After rolling back to 10:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Aug 07, 2008
Philips go gear sa3245/97 not starting
You can download content to a Philips GoGear multimedia player using Windows Media Player or MusicMatch Jukebox in Windows. Earlier versions of Windows starting with 2000/ME and XP are compatible with GoGear. If the device is not recognized by the Windows XP operating system or is receiving error messages, you may have older versions of the necessary software installed. There also may be firmware issues with the GoGear device.
Instructions
Connect the Philips GoGear to another USB port on the computer. Sometimes USB ports go out, especially those in the front of the computer case. Try inserting the GoGear into another port and see if XP can now recognize the device.
Download Service Pack 1 or later for the XP operating system (see Resources). Philips GoGear can only operate on XP systems with at least Service Pack 1 installed. You may also receive an error message pertaining to the service pack when trying to insert the installation disc for the GoGear support software.
Install the latest version of Windows Media Player. Philips GoGear requires at least Windows Media Player 11. Windows Media Player 11 is available for XP .
Install the latest version of MusicMatch Jukebox (see Resources). Earlier version of this software may be causing error messages regarding missing MP3 tag information and missing tracks. Follow the download prompts, then unzip the folder and click on the "HDD_xxx.exe" installation file. The latest version of the software will be installed.
Install the latest firmware on the Philips GoGear. The actual firmware required depends on your GoGear model. Open either Philips Device Manager or Songbird, depending upon which management software you are currently using. Close all programs on the computer except for the Device Manager/Songbird. Connect the GoGear to the power supply and the computer. Click the "Repair" tab in the Device Manager and click "Repair," or click "Tools" in Songbird and select "Check for updated firmware," and the firmware will be updated on the GoGear.
Mar 31, 2011 | Philips Audio Players & Recorders
Tip
USB Printer does not recognize with XP Computer
In most cases, the driver for a printer is supplied when you purchase it. It is the responsibility of the manufacturer to provide the driver along with the device to make sure the working.
However, most of the Operating Systems come with native driver support for many known printers. This is the fact we have to take care while purchasing a printer. Even though we misplaced the driver disc, if we purchase a good manufacturer printer, there is a chance to get the native support from Operating System itself.
There are some scenarios where printer may not be recognized by the Operating System due to some conflict with other devices.
Please follow the troubleshooting steps and check the operation:
  • Ensure that the supplied USB cable is firmly connected to both the printer and computer side.
  • Ensure that the USB driver for the printer has been properly installed. Please follow the steps to ensure that:
  1. Turn ON the computer and then printer.
  2. The Add New Hardware Wizard window will appear on the Computer screen.
  3. Click the Next button
  4. Insert the installation CD in to the CD/DVD drive on the Computer.
  5. In the Add New Hardware Wizard window, click to select the CD-ROM drive.
  6. Click the Next button.
  7. In the Finish Setup dialog box, click the Finish button.
  • If the USB driver for the Printer has already been installed, uninstall and then reinstall the driver.
Follow this procedure to reinstall the device driver using the Device Manager utility.
IMPORTANT: This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  1. Click the Start button, and then click Control Panel.
  2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
  3. In the Performance and Maintenance window, under or pick a Control Panel icon, double-click the System icon.
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, in the Device Manager box, click the Device Manager button.
  6. In the Device Manager window, double-click the category icon of the device to be removed.
  7. Under the Device Manager category, click to select the device to be removed.
  8. On the menu bar, click Action.
  9. On the Action menu, click Uninstall .
  10. In the Confirm Device Removal window, click the OK button.
  11. Restart the computer.
NOTE: For some devices the operating system will display a System Settings Change window. Click the Yes button to restart the computer. When the computer restarts, the operating system will find the device and install the driver. If the operating system is unable to automatically find the driver, have the installation wizard search the C:WINDOWSI386 folder.
  • Remove and reconnect the printer.
does not recognize printer XP computer does not recognize printer. HP printer computer connectivity how to troubleshoot if printer is not connecting to my computer. XP printer issues. how to troubleshoot printer conncting with XP Computer. XP does not recognize printer. Printer is not connecting to my computer. how to reinstall printer driver. how to install native driver for printer. CANON printer is not recognized by the Computer. Epson printer is not recognizing. Epson does not recognize XP. Canon Printer connectivity.
on Jan 27, 2011 | Office Equipment & Supplies
My mp3 philips go gear shows the message: connect to pc and use device manager to repair
if you still have the CD's the device manager is included with them. install it and use it. if you are using win xp sp3 or vista/win7 you will need to visit the site-->support page-->find your device and look for the device manager download. alternatively (worked for me on a 6gb) you can open my computer while the device is plugged in and recognized right click the philips mp3 icon and click format, this will erase all of your music and images but it should recover your mp3 player. if this does not work use the program from the site/your CD's
Feb 08, 2010 | Philips SA3125\02 MP3 Player
How to fix sansa clip rhapsody installation problems. it says i need to trouble shoot at 99% and then it stops. i alredy downloaded the firmware and it still does that
IMPORTANT: To function properly, your Walkman® player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media® Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue. For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
If the issue persists, please Click Start and then click Control Panel . In the Control Panel window, click Performance and Maintenance . In the Performance and Maintenance window, click System . In the System Properties window, click the Hardware tab. On the Hardware tab, under Device Manager , click the Device Manager button. In the Device Manager window, click the plus (+) sign in front of Disk drives . Click to select the Sony USB device . From the menu, click Action and then click Uninstall . In the Confirm Device Removal box, click OK . Disconnect the portable player from the computer. In the System Settings Change box, click Yes .
After that, restart the computer and reconnect the player
Sep 21, 2009 | Audio Players & Recorders
When i turn on my mp3 getting error as " connect to PC and repair through device manager"
If you have lost your installation CD, go to Philips website and download/install the most recent version of the Philips Device Manager for your exact model #. Then open the Philips Device Manager and select the "Repair" button (with your mp3 player connected to the computer, of course).
If the Device Manager does not recognize that your mp3 player is plugged into the computer:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 20, 2009 | Philips Audio Players & Recorders
Computer wont recognize sansa fuze
STOP EVERYTHING ALL YOU HAVE TO DO IS TURN OFF YOUE SANDISK, THEN plug it in!!.
Feb 01, 2009 | SanDisk Sansa Fuze MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Jan 23, 2009 | iRiver iFP-795 MP3 Player
Good morning, my go gear is stuck, it will not allow me to operate any of the buttons. It just stay on one screen, and the computer does not recognize the go gear Hello. I'm having the same problem with...
Make sure the hol/lock is not engaged. As logn as it's not engaged, run the Repair in Philips Device Manager. If the Device Manager will not recognize the player: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
Jan 06, 2009 | Audio Players & Recorders
My Computer and iTunes does not recognize my iPod
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Nov 24, 2008 | Apple iPod nano
"Please connect player to PC"
Go to www.philips.com and download the hhdd1630/17b software and firmware updates. Install them and print off the instructions on what to do. This fixed my player and what a difference it made.................WOW
Sep 11, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
179 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
