I have a problem with HP Photosmart C8180 All-In-One: Error Oxc 19a007 How to prceed? BR, Seppo Karikko
    Problem Solver:
  • 9 Answers
Errors like 0x is refered to the ink system failure,posible causes are clogged printhead usually photosmart print has a tool inside the machine that can clean the printhead: on the front panel or on the screen touch or press the set up menu/thats the button that has the wrench icon/go to tools then press ok/under tools look for clean printhead/after cleaning the printhead go under tools aain then look for align printer if you got alignment successful messae youre good to go..but if symptoms persist check your ink maybe it dried and run out/check ink level/reset printer by turning on the printer then while the printer is on uplug power cable at the back,wait 15 seconds then plug it back in...if you still have the replace printhead...
Posted on Mar 28, 2011
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_beef7390c57fac0d
Jun 24, 2014 | United Stationers HP Photosmart C8180...
C8180 oxc 18a0306
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
Dec 23, 2011 | HP Photosmart C8180 InkJet Printer
HP C8189 All in one printer....Error Oxc 19a0005
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. Use a moist cloth to clean the nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the cartridges.
Now see if its working fine. Let me know.
Dec 02, 2010 | HP Photosmart C8180 InkJet Printer
Ink failure ink system failure error oxc 18a0001
The "ink system failure" error is caused by air in the ink feed tubes. We have 2 articles posted on our web site giving step by step guides to purging the air from the tubes and clearing the error. You can find the articles at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C8180 InkJet Printer
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
OXC : stoped printing
OXC? what would that mean, by chance? Is that an error code?
Oct 25, 2007 | HP Photosmart C7180 All-In-One InkJet...
406 people viewed this question
k24674
jasbo
jasbo
