Question about Bugaboo Gecko Stroller
Handle bar will not longer allow collapse suggestions please - bugaboo gecko.
    Guru:
  • 541 Answers
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods or broken locking rods.Why bugaboo uses plastic for the disk and aluminum for the locking rods is beyond me!They are critical components with a history of failing and should be made in stainless steel.
1/.Remove the capped star lock washer.This is the hardest part of the job.Most people try to leaver this off in the hope of re using.First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement.A hardware store should be able to source some for you.Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit another screwdriver under the starlock.Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel.Use one screwdriver as a support and another to lift off the capped star lock.handle bar will not longer allow collapse - macnutz_2.jpgNote it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side.The hubs and disks are mirrors of each other and not interchangeable the locking rods are interchangeable.The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/.The lock mechanism is very simple; a wire rod rotates a plastic disk.Check the hubs for wear.If too badly worn or damaged you will have too much movement in the locked position.The Frog, Gecko and Chameleon use the same plastic hub so find another frame to salvage hubs from.They are held in by a single aluminum rivet.
The disks have two plastic pins that move the locking rods in and out of the inner hub. Locking into and out of the outer hub.You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in.Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.The locking rods can only be replaced, either by ones salvaged from another frame or new laser cut copies.I prefer the copies as they have been cut from stainless steel.
3/.Reassemble handle locking hub and check operation.If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws (note I'm now finding some frames now have pop rivets, drill them out and replace with self tappers) and wiggle things into alignment. (I use a small amount of the silicon grease used for taps to give a smooth action)If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern.Repeat operation handle bar will not longer allow collapse - macnutz_1.jpgside.
I can't emphasize enough the need to keep Bugaboo hubs well lubricated with silicon spray.They have to endure incredible forces from the handle.To give you some idea, a crow bar of the same length can pull six inch nails out of hard wood!
I do have parts available: laser cut metal disks with stainless steel pins, replacement-locking rods in stainless steel and capped star lock washers. You can contact me at macnutz@xnet.co.nz
Posted on Mar 29, 2011
Please send instructions manual for bugaboo gecko
Hi, you can download the instruction manual for the Bugaboo Gecko at http://www.freebabymanuals.com/bugaboo/prams
Hope that helps
Jun 10, 2010 | Bugaboo Gecko Stroller
Use of Bugaboo bumper bar for Bugaboo Gecko
In short, no! There is no way for a bumper bar to be attached to a Gecko model.
Hope this clarifies for you.
Feb 22, 2010 | Bugaboo Gecko Stroller
Can you get a bumper bar for the bugaboo gecko?
In short, no is the answer for this one, sorry!
Jul 08, 2009 | Bugaboo Gecko Stroller
How do I collapse bugaboo stroller
take off the basinette or seat
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
Jun 21, 2009 | Bugaboo Frog Stroller
Bugaboo Gecko Collasped Chassis won't open.
To open the Gecko, follow the steps below:
Stand behind the folded stroller, ensuring the handle is on the top of the stroller.
Bend down and place your hands on the handle bar, DONT lift the pram, make sure it stays on the floor.
Push the white button on the inside of the left hand side of the handle bar.
Pull both triggers (located inside of the handle bar) toward you and lift the handle up.
Stand up-right, and place your foot onto the bottom of the two axles which you can see in front of you (make sure that you have your foot on the axle which connects the two small swivel wheels).
Whilst you are standing, with your hands on the handle bar and your foot on the axle, push the axle outwards with your foot away from you and slightly upwards. This should open the chassis up-right. Please note that the chassis will appear to be unstable and move, this will stop the minute that you click on your carseat/carrycot or seat unit.
I hope this helps.
Mar 05, 2009 | Bugaboo Gecko - Green Standard Stroller
Handle over the big wheels
To move the handle bar (either for folding or to change into the off-road mode) push the small white button in (located on the inside of the handle bar) and pull both triggers toward you (also located on the inside of the handle bar - on either side) This will enable the handle bar to move.
I hope this helps.
Feb 24, 2009 | Bugaboo Gecko - Green Standard Stroller
Handle will not fold down any more
We hand handle problems, and no receipt. I just called bugaboo with a serial number and they sent a new chassy.
Nov 25, 2007 | Bugaboo Gecko Stroller
Shaky Handle bar!
Here's the link to the "user manual" which I assume you already have; http://bugaboo.com/userguides/UG_G_NA_en.pdf I have never seen a product that had so many "warnings" that this product has. I'd start by making sure all the "clicks" have been made when setting it up. Look for any loose screws, nuts or damaged parts. If you still don't feel comfortable, (and I wouldn't) I'd call their 800 number listed in the manual. I warenteed for 2 years.
Aug 23, 2007 | Bugaboo Gecko Stroller
Bugaboo Gecko Stroller Logo
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
