I want steps - Computers & Internet
  • 2,069 Answers
But you want steps to do what? please enter as enough problem description as possible and someone will assit you better. thanks fo using fixya!
Posted on Mar 28, 2011
How do i connect my xbox 360 live to my belkin F7D8302 N600 Wireless Dual-band N Router
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Now lets configure
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Scan and connect to this network and test the connection
If working then let me know
Jan 18, 2011 | Belkin Basic Wireless Router
I have my ps3 connected to belkin router but connection keeps failing and i dont have a moderm. where i stay at has wifi. what can i do
BELKIN ::::
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
TO OPEN PORTS FOR PS3
Step 15:Enable UPnP
Step 17:Test the connection ,Check the NAT
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Dec 23, 2010 | Belkin Basic Wireless Router
How to replace an intake manifold gasket on a 1996 gmc jimmy
Here is a detailed summary on the procedure of how to replace the intake manifold gasket on a 1996 gmc jimmy;
REMOVING THE UPPER INTAKE MANIFOLD(PLENUM)
STEP 1 Disconnect Battery (may not be absolutely necessary, but a good practice to avoid shorting a positive wire to ground).
STEP 2 Remove serpentine belt.
STEP 3 Drain the coolant.
STEP 4 Remove air cleaner ducting and disconnect wires.
STEP 5 Disconnect throttle linkage and bracket.
STEP 6 Disconnect cruise control cable.
STEP 7 Remove brake booster vacuum hose at manifold.
STEP 8 Remove PCV hose.
STEP 9 Remove ignition coil and bracket.
STEP 1O Remove purge solenoid and bracket.
STEP 11 Relieve fuel pressure at test port.
STEP 12 Remove fuel lines and bracket.
STEP 13 Remove upper intake manifold.
REMOVING THE LOWER INTAKE MANIFOLD
STEP 1 Remove the distributor and label the spark plug wires.
STEP 2 Remove heater hoses and bypass hose.
STEP 3 Remove upper radiator hose.
STEP 4 Remove EGR valve?
STEP 5 Remove sensors and bracket on right side.
STEP 6 Remove EGR tube, clamp and bolt.
STEP 7 Remove PCV valve (and replace).
STEP 8 Unbolt A/C compressor and move it aside.
STEP 9 Loosen compressor bracket and slide forward, but do not remove it.
STEP 10 Remove alternator bracket bolt (or remove alternator and set aside)
STEP 11 Unplug all vacuum lines from intake manifold.
STEP 12 Unplug all electrical connectors from manifold.
STEP 13 Take note of the intake manifold bolts and mark the location of the bolts.
STEP 14 Remove intake manifold bolts, and manifold.
STEP 15 Clean mating surfaces
THE MAIN INSTALLATION
STEP1 Set the new gaskets in place and apply silicone to flat areas on front and rear of engine block.
STEP2 Apply thread locking compound to manifold bolts.
STEP 3 Install the manifold and tighten bolts to 35 ft-lbs, in proper sequence.
STEP4 Install the distributor.
STEP5 Install the upper intake manifold.
The remaining installation procedures are basically the reverse of removal.
Have a nice day.
Dec 04, 2010 | 1996 GMC Jimmy
I need my wep/wpa pass phrase
just configure again your router.
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
======= WIRELESS SETTING UP A WIRELESS CONNECTION ================
Oct 10, 2010 | Belkin (F5D8231-4) Wireless Router...
Dont know how to set it up from my home computer do i hook the router to my modem then put the disk in the tower on my desk top im trying to get my laptop to run off the wireless router but they said i got...
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Sep 19, 2010 | Belkin (F5D7231-4) Wireless Router
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
How to set a password for the router thanks
Step 1: Connect your computer - Router ( Wired)
Step 2:Make sure that the wireless is disconnected in the laptop
Step 3:Open Router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 4:On the left under wireless click Wi- fi protected setup
Step 5:Leave the Password blank and click submit
Step 6:Disable it and click apply changes
Step 7:On the left under wireless click security
Step 8:Selected the security mode as WPA / WPA2
Step 9:Type a password in the blank field ( Pre Shared key or PSK )Make sure that the password is a minimum of 8 characters
Step 10:On the left under wireless click channel and SSiD
Step 11:Change the Wireless Channel to 6
Step 12:Change the SSiD to a different name
Step 13: Click Apply Changes
Step 14:Unplug the power cord from the router
Step 15:Plug it back After 15 seconds
Step 16:Now try to connect to the new network
Goto belkinrouters.blogspot.com for more
Aug 03, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
Legal size paper on LBP-1210
Step 1- Go to start
Step 4-go to file
Step 14-then close
Step 21-select OK
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
