Question about Brother HL 5250DN Laser Printer
I have a HL 2070 Brother printer That that toner light will no go off, I replace with a new toner and after that did not keep working, I tried to reset the toner opening the front door, also holding the go button with the door open, what is other option to reset the toner light?
    Novelist:
  • 129 Answers
Hi there!
You can remove the drum and toner, remove toner from the drum unit then gently rock the toner from side to side for about six times to distribute the toner inside, then on the drum unit slide the green tab on the upper left hand from left to rigth for about six times and then put it back to the home position. Reinstall the toner back to the drum unit and then put the drum and toner back to the printer. closed the front cover. the toner light should turn off,
Hope this helps.
Posted on Mar 28, 2011
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
HOW DO I REMOVE SPEND TONER IN HL 2070 N and insert new toner
open front cover, pull out drum/toner unit, press lever to release toner, put in new one,and replace.......ta-daaa
Mar 04, 2009 | Brother HL-2040 Laser Printer
DRUM LIGHT KEEP FLASHING
Take the drum out and wrap it up to keep the light out of it.  Check the contacts inside the printer and make sure there is nothing broken on them.  If there is toner on them, try to clean them off.
Oct 06, 2008 | Brother HL-2040 Laser Printer
HL 2070 Printer Toner light will not go off
Ok, I’m going to try and explain this without pictures:
Take out the toner and look at it. One end has 2 silver screws in it. As you are looking at the toner from the front (transfer roller pointing at you) the screws are to the right. Remove these screws and so remove the face-plate. There is a white gear-wheel (without cogs/teeth) that looks a little like a Y. This simply lifts off; behind it is also a metal spring. Remove this gear and the spring. Now replace the face-plate and the 2 screws without the gear and the spring. That’s it. Put the toner back in and print until no longer possible as the light will not show when it really is empty.
Hope this helps.
rigsby
Jul 27, 2008 | Brother HL 5250DN Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
May 01, 2008 | Brother HL-2040 Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL 5250DN Laser Printer Logo
288 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
