Question about Bosch & Tankless LP Hot Water Heater
Bosch 10p, the pilot light went out, when reigniting i pressed the shut off button, now it is locked in and i cant release it, is there a reset button somewhere? regards
Bosch Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
For Bosch tankless troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For Rheem tankless resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 28, 2011
We have had major blackouts does my bosch highflow 21e need to be reignited or automatic....how long should it be until I get hot water
you have to reignite it yourself turn dial to pilot and press down the light with either the internal igniter or a long match when lit then you turn dial to the ON position .
Apr 25, 2015 | Bosch Water Heaters
Relight combi pilot light?
These are designed not to light once the thermocouple fails.the thermocouple has a small wire that positions in to the pilot light which checks the pilot is on and keeps the gas governed.once the temperature drops it shuts off the gas to prevent a build up of gas in a room where a pilot light has gone out.this is why you need to hold the button in on reignition to allow the thermocouple to heat up so the gas keeps open.
Try to relight by turning on the gas ....pressing down and holding the button for at least 10 seconds whilst firing the piezo to ignite flame.do not release gas button for at least 10 seconds then slowly release.if the flame on the pilot will not stay alight....then it is likely the thermo has failed.try cleaning the metal wire that is above the pilot jet.still no joy then it needs replacing.hope my comment is of help...please vote.
Feb 19, 2015 | Water Heaters
Bosch 10p hot water system off button wont pop out!
Wiggle the button while pushing and releasing, maybe it's caught on the casing it's in.
Jun 13, 2012 | Water Heaters
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
Water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
My bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch water wizard 600 pilot light out
First check your gas supply, gas in bottle or lines? I know, this is basic & I'm not having a shot at you, but you'd be surprised at how many times it gets overlooked.
If you do still have gas supply, evident by that low hiss when you hold the pilot feeder button in (you might have to lean in close to hear it), then you need to check that the piezo is working. This is the bit which produces the spark to ignite your pilot. You will be able to see it sparking at the pilot outlet when you push the button (if you're looking in the right spot).
Ok, you have gas & a working spark? Not sure which buttons to press?
You mentioned the manual no longer being in a helpful condition...do you know which of the 4 buttons, 2 taps, 1 slide control & 1 dial do what?
Well just in case, here we go in simple form... first button on the left is the pilot feeder (lets gas through the pilot), second button from the left is the 'ON' button, third from left is the 'OFF' button & the fourth from the left is the piezo ignite button (gives you that much needed spark!). The slide controls your flame (how much gas gets fed to it). The dial, below the pushbuttons & slide, controls how much water flows through the system which then helps regulate the heat. Make sure the taps on your gas & water lines to the unit are on. There you go...2 taps = gas & water supply, 4 buttons = pilot gas, on, off, piezo (spark), 1 slider = gas/flame control, 1 dial = water flow control.
Ok let's see if we can light it! Water & gas supply turned on, slider set about 25% from left, dial set roughly in the middle, push in button 1 (1st from left) & hold in for about 10 seconds, you should hear a very faint hiss from pilot area. Yes? OK, keep holding button 1 in & press & release button 4 several times until pilot lights, you may not see a difference but if you can't see it and it does light you will hear the faint hiss change to a soft fluttering sound as the flame consumes the gas. Still OK? if so then the next step is to push in button 2 quite firmly & then release button1 as well. If all works as planned you will shortly have hot water supply restored.
If the above has not worked then your hot water service may just need a service to clean everything up & maybe replace a few worn or excessively corroded parts. Otherwise ,if there are no blockages in supply lines etc, then it may be time to replace it.
You neglected to say how long you've had it.
Cheers, hope this has helped.
Dennis
Feb 18, 2009 | Water Heaters
Cant get my waterheater lighter to reignite
Sounds like the gas valve has failed. The gas valve can be replaced. It will unscrew out of the tank. Shut the water supply to the tank off and get the new gas ready to screw in. Take out the old and screw in the new, you will onlt lose about a cup or two of water if you are quick enough. Otherwise drain the tank down if you must. If you are going to replace the gas valve I would also replace the thermocoupler.
Dec 18, 2008 | Water Heaters
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Bosch & Tankless LP Hot Water Heater  Logo
1,053 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
