I have press fn f8 key and it toogles the display now ho to come bake to the normal
  • 2,632 Answers
Welcome to Fixya.
You need to press FN + F8 again to go back to the original screen.
Thanks for using Fixya
Posted on Mar 28, 2011
    Brigadier General:
  • 8,909 Answers
Press FN + F8 again until it toggle back.
4 Suggested Answers
  • 4 Answers
SOURCE: fn key is constantly on
i just solved this problem today on my packard bell easy note all you have to do is hold the FN key and press NUMLK and then it should work
Posted on Jan 02, 2009
  • 40 Answers
SOURCE: function key locked on
did you spill something on the board? If so, you won't fix that, you'll need a new board. If not, dismantle it and adjust the rubber underlayment. Clean it good. If you did spill something , don't bother trying to clean it. You'll find you wasted your time.
Posted on Jul 04, 2009
SOURCE: my laptop keyboard is stuck using the Fn keys
is your number lock on? if it is turn it off and everything should be fine...
Posted on Dec 07, 2009
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
No display upon turn on
Did you press and hold the FN function key plus the key that toggles the display? In your case it might be the FN+F8 if F8 is the key that toggles the display.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
Jun 10, 2012 | ASUS Eee PC 1005HAG Notebook
My fn key wont work on toshiba sattelite pro
FN (Function Key) that is usually located near the bottom left on the keyboard is not a key that you press by itself to do anything. The FN key works in combination with the (F1 thru F12) and any other key that has the same symbol or color as the FN Key. You have to Press and HOLD the FN key while pressing another key.
If the FN key is Blue and for example your F8 key has a (white F8 on it and a Blue battery icon on it) then to see your battery metor (how much charge it has left) you would Press the FN and hold it then press the F8 key. The F8 that is white does not require you to press the Blue FN.
Sometimes the FN key might have a white square on it, then the keys that work with the FN key will also have a symbol with a white square around it.
Mar 25, 2012 | Toshiba Sattelite® Pro A200 PC Desktop
How can i get my fn key to work
XPS M1210 Laptop turn on but no display
Mke sure your displ;ay is selected, hold down the Fn key and press the F8 key.
Connect a know working monitor to the laptop, again hold down the Fn key while pressing the F8.
If the external monitor works then your display is defective, if not then the onboard video is defective and you will need to replace the mother board.
I hope thisd helps.
Good luck and have a pleasent day.
May 17, 2011 | Computers & Internet
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
Latitude d505 won't display image through projector. Being used with Sanyo plc XU41 and Promethean board. Board is interactive but no help if there is no image to see! Other Dell laptops work with this...
Dell laptops normally have a 3-way toggle for the display destination: 1=screen 2= external display and 3=Both. To toggle from one mode to the next press hold the 'FN' key (lower left corner of the Key board), and the briefly press the 'F8' key. Wait a few seconds for the hardware to catch up and you should see a display through the projector. If not, repeat the 'Fn' + 'F8' combo again.
You could also try running diagnostics to verify that teh video card is working properly. To do that, sthar with the laptop off. Hold the 'Fn' key down while you press the power button. Release both as the machine begins to boot up. It should start in diagnostics mode. Run the quick test and watch for the color bars. If you see then, the video card so=huold be OK.
Good luck, And please let me know how it turns out for you.
~ Spoem
Oct 01, 2009 | Dell Latitude D505 Notebook
Compaq armada m700 display problem
Try and toogle your FN key or connect an external monitor and toggle on FN key
let me know what happens....
Jan 31, 2009 | Compaq Armada M700 Notebook
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
300 people viewed this question
Alun Cox
David Payne
David Payne
