Had replaced lopter and then it blew capacitor next to it. Can not switch it on
    Brigadier General:
  • 8,909 Answers
By 'lopter' I expect you mean Loptx?
Need more information than what you have given. Make, model etc and what components have been replaced that caused the fault in the first place etc
Please send your question again.
Posted on Mar 28, 2011
I replaced my power supply on my Tv. The new part I got blew out on me.
Did you replaced the power supply as card basis; or, repaired it by replacing any capacitors at it. If you have replaced the capacitors only, the polarity of the capacitor you've replaced might be reversed. Capacitors have both +Ve and --Ve polarities, and should match with the markings at the board; otherwise it will burst when you power it up.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 22, 2014 | Vizio VF551XVT 55 in. HDTV
I have a Kenmore 70 series. I just replace the door switch The machine was working and it agitated just fine. It was not draining though, but I could hear the water pupmp working just no water. A minute...
Them capacitors do die. I replaced one just last week:
Tip go by the micro farads and you can get one cheaper than buying the OEM. I paid $3
I have a dedicated page from lid switch to transmission on
your machine with videos and service manuals HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 09, 2011 | Kenmore 24032\24036 Top Load Washer
Start capacitor keeps blowing. saw starts up
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
May 13, 2010 | Diamond Products Mk - 101 10" Tile Saw
Have a Toshiba MW24F11 combo tv. Near lightning strike through surge suppressor. Will not turn on. 6.3 amp fuse blown; replace, blew again. Next step, or start looking for replacement. Set is 25...
power surges generally damage diodes and capacitors causing the fuse to blow, any reputable tv shop can repair for a fraction of replacing this set.
Sep 15, 2008 | Televison & Video
Blown Capacitor and diode
I had the same problem. My nephew gave me this set after it quit working at the Gym where his wife was working. They were going to junk it but I asked if I could try and fix it.
The capacitor C2250 was definately blown and easy to spot so I did some searching and found a replacement from an online electronics supplier that didn't require me to buy 200+ as Digitech wanted. Anyway I replaced the Cap and it still didn't work so I started looking and testing components again and found that the Diode D2250 was bad so replaced it as well and now the set works fine. Maybe this is what is wrong with your's and others as well.
It made sense for me to check the diode as it is right next to the cap that blew. https://www.mouser.com for the Cap and http://www.slelectronics.net/ for the Diode.
The specs for the Cap/ CERAMIC CAP. B K 1500pF/1KV
The specs for the Diode/ SCHOTTKY BARRIER DIODE YG123S15
Hope this helps
Aug 25, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Ilp iwt3206 32" sdtv
Next best guess is the larger filter capacitors in the power supply are bad and shorted out, you can check with an ohm meter across capacitor leads (with power unplugged)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
