FixYa.com
Tags:
IBM NWAYS Router 2210 Model 24M
Lotus and network
By paulrmc - usenet poster
big problem! all my firm is IBM. my lotus server is in my AS/400 (FSIOP) my
AS is on a Token network as my server lotus. I ping my IP lotus adress with
no problem from a Pc (IBM of course 350, 330, thinkpad 380,...)which is on
the token but when I'm on one which is in an ethernet no way. other firm are
connected to my network thank router (IBM of course 2210 24M and 1S4) and no
way to ping IP adress of my server. I can ping so communicate with all other
device on token. only the IP adress of Lotus is not reachable. PLEASE HELP
IT'S VERY IMPORTANT
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Kyle,
Is you are running Domino on an IPCS you have to configure a default route
on the network server description.  The IPCS runs OS2 and has its own host
table and routing table.  It will not use the AS/400s routing table.
You need to vary off and on the IPCS to get the new rout to take effect.
Regards,
Jason Marston.
CLP - Administration
Tony Johnson <at-john @email.msn.com> wrote in article
<eN9NgSvq9GA.297@upnetnews03>.­..
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
Thanks for all your answers, the solution was a specific route table for the
IPCS.
now everything works great.
Thanks again.
P.S. does anyone have information about sharing a Notes server (which is on
a IPCS).
Solution #3
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
The routing table on the AS/400 is suspect (or at least on the FSIOP).
I'd look in that direction.
On Thu, 25 Jun 1998 17:26:14 +0200, "Fabien Guignon"
Solution #4
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
: big problem! all my firm is IBM. my lotus server is in my AS/400 (FSIOP) my
: AS is on a Token network as my server lotus. I ping my IP lotus adress with
: no problem from a Pc (IBM of course 350, 330, thinkpad 380,...)which is on
: the token but when I'm on one which is in an ethernet no way. other firm are
: connected to my network thank router (IBM of course 2210 24M and 1S4) and no
: way to ping IP adress of my server. I can ping so communicate with all other
: device on token. only the IP adress of Lotus is not reachable. PLEASE HELP
: IT'S VERY IMPORTANT
it is difficult to understand exactly what you are saying, but I believe
this is not a notes problem...it is your network topology...you need to
get a bridge or a route that will integrate your ethernet and token ring
network..
I assume that you have a router setup (since you are using as/400 and pc's,
it wouldn't make sense not to), the router hardware / software is not
does not sound like it is configured to send packets the other network.
Kyle Huang, mcse
kyle
cosc1 @menudo.uh.edu
-or-
khu @technicalstar.com
Solution #5
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
The routes are configured in the NWSD (use CHGNWSD from OS/400 to
change).  The host table is copied from the AS/400 host table.  Use
CFGTCP to change.
Solution #6
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
I agree, it sounds like your Token Ring and Ethernet networks are not
bridged correctly.
i forgot who i am! wrote in message <6mu2fj$96 @Masala.CC.UH.EDU>...
Solution #7
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
I think you're right but i have no knowledge about configurating routing
table on the FSIOP which is an OS2.
do you have any information about it.
Thanks for your answer.
Rocky Marquiss a ??crit dans le message
<35928078.95489 @newslink400.com>...
Can you Help with these Routers problems?
Routers
Wireless and Wired Router
I currently have a desktop and... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
