Beko washing machine is not spinning and it violently shakes from side to side crashing against cupboards next to it so much that it damaged them. After 1 attempt at spiining the machine becomes idle.
  • mikepemberto Mar 29, 2011
    Hi john_cross,
    Thanks for your prompt and very helpful response. The machine is positioned securely and all legs are firmly positioned. Do you have any suggestions regarding the fact that the machine is not able to spin. it is as though it is trying to spin but the drum cannot rote. this is when the machine starts rocking violently.
    Brigadier General:
  • 6,277 Answers
So that the washer can spin properly without rockin' and rollin' (and without doing damage to itself!), it is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 28, 2011
Testimonial: "very prompt and helpful response"
  • 3 more comments
  • john_cross Mar 29, 2011
    Hi again,
    Then maybe my last paragraph is relevant- concrete block(s) broken, shock absorber(s) malfunctioning, drum support(s)/spring(s) or the large pulley. Have you had the chance to look inside?
    John C
    I am a complete novice with washing machines so have not looked inside as I would not know where to start. Do you have any advice/pointers for troubleshooting the inside of a washing machine and identifying the issues you have mentioned?
    I am having to assume that it is a front loader; I have less experience of top loaders. Disconnect the power! Pull the machine out so that you can access the back which you should unscrew. Facing you will be the back of the drum with the big pulley around which is the belt which in turn (!) goes around the motor.
    If you hold the drum it should be fairly difficult to move it around but in doing so you should be able to see/feel/hear if anything is not as it should be! As an alternative, with the back still off, you could run the machine with some garments and water in it, making sure FIRST that it is still level/balanced but obviously taking great care to be safe whilst looking and listening.
    This might help identify if something is broken/malfunctioning inside.
    Good luck again, John C.
    PS Sorry but it's 23:28 in SW France and I must get some sleep ;-0)
    Hi yet again, another reason for the non-spin could still be the motor if there is no obvious breakage. Not uncommon for a motor to work reasonably normally on wash cycles but to fail on (fast) spin. I'll wait for your results!!
    J
  • mikepemberto Apr 03, 2011
    Thanks again for your help. I opened up the machine and checked the pulley, supports etc and ran the machine with the back off. I have however deduced that the problem is a malfunctioning motor and am cutting my losses by purchasing a more reliable Bosch machine. Many thanks again for your prompt and helpful replies.
    Regards
My washing machine shakes during spin mode
The machine must be level or it will shake. There should be feet under the front which screw in and out. Get a spirit level and adjust the feet so it is sitting level front to rear and side to side.
Also make sure it isn't rocking slightly when it's not running - if so screw out one of the feet till it's steady. If you don't have a spirit (bubble) level compare how vertical the sides are to the wall/cupboards etc. However a level is best as even a little lean can make it shudder.
Or your putting too much washing in it!
Feb 07, 2013 | Whirlpool Washing Machines
SHAKES and VIBRATES - LG Front-loader shakes and vibrates terribly during the spin cycle. It is pounding against the walls and the dryer thats next to it. Its also very loud and it used to be super quiet...
try putting a lighter load in the washer,or you put some foam or something like that at each side of the machine to stop it hitting against the other things next to it.also try adjusting the feet at the bottom of the machine to level it out.
Jan 31, 2013 | Washing Machines
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
Shakes violently on every spin cycle
Your washing is off balance (stuck to one side of the drum), next time, open the door and shake the clothes so that they are evenly spread. If this continues it can cause serious damage to the spindle on the motor and these con only be replaced as a new unit and very expensive.
Oct 03, 2010 | Washing Machines
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
On high spin the drum bangs against the rear inside walls of the cabinet. Dents are noticable from where it violently shakes.
There is usualy a switch located under the agitator that senses when the machine is spinning off balance. What are you drying? But it sounds like a bad off-balance switch.
Dec 16, 2009 | GE Washing Machines
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Shakes violently
The bearings of you machine are damaged or bad..You have to get em' replace..until then lowering the water pressure will solve this problem to some extent..
Oct 24, 2007 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
414 people viewed this question
Top Washing Machines Experts
