Question about Sanyo Televison & Video
On/off switch broken - Sanyo Televison & Video
    Brigadier General:
  • 8,909 Answers
Spares can be obtained from most TV repairers or from chashide.co.uk
Posted on Mar 28, 2011
Thanks.. I have a onan 7500k living in from the storm. Will not start with remote inside switch. But you can shut it off with inside switch. Outside switch works great.
Need more info.
Inside does it have an 'on/start' switch and a separate 'off' switch ?
If it does -
1) the start switch is bad.
2) could be a broken/loose/corroded wire at the start switch 3) broken/cut wire to the Onan
4) broken/loose/corroded wire at the Onan where the inside start switch connects.
The fact that it starts at the Onan tells you it's OK.
Sep 17, 2017 | Electrical Supplies
What's your question?brother dcp115c,machine error51?
Brother DCP115C Code: 50, 51
Description
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
Sep 09, 2016 | Brother DCP 115C All-In-One InkJet Printer
Machine error 50 . dcp-115c
Jul 26, 2014 | Office Equipment & Supplies
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2012 | GE Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Samsung notebook N150 on/off switch broken
One of two things is broken. 1) the rear fork of the plastic switch is suseptable to bending a breakage. 2) The springloaded switch whick is soldered to the base circuitboard could also be broken.
Jun 05, 2011 | Samsung Tablets & eReaders
Broken ignition switch in 1986 m/b 560sel Have
you will have to replace the lock barrel(not cheap)
Apr 06, 2010 | 1991 Mercedes-Benz 560
Wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
Oct 04, 2009 | Acer Aspire 3680 Laptop
Broken on/off switch
need to replace the on/off switch for this camera. I have the broken piece that cannot be repaired. How can i find a replacement switch. I can repair the camera myself with the new switch. thanks.
Jul 19, 2008 | HP Photosmart M425 Digital Camera
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
