Question about LaCie Starck Mobile - hard drive - 320 GB - Hi-Speed USB USB 2.0
LaCie Starck USB Mobile Hard Drive is not detected
  • rebeccaguppy Mar 28, 2011
    I have read though but i have a pc and when i go to -Start/ My Computer there is no Lacie icon..
  • 42 Answers
Http://www.lacie.com/support/drivers/index.htm?id=10013
go to above link and search for your required driver
if your problem persists please let me know
if you are happy with my solution please rate me high and vote for me
Posted on Mar 28, 2011
I formatted my lacie 301891 (320 GB) and his capaity is now only 9,99 MB what did i do wrong?
You may have partitioned your hard drive. Have a look at your Computer Management Console by right clicking My Computer > Manage. Then under Storage, select Disk Management.
Jul 14, 2011 | LaCie 301891 320GB Starck Mobile Portable...
Since purchasing and mounting the Starck 1TB drive I have had problems with this when attempting to mount both drives - I had to reformat the older drive - it worked fine until I tried to mount the Atarck...
Greetings,
I would try another USB connection/bus. For example, have one drive on the front ports of your system (if it has them) and then the other drive on the back ports. Additionally, if both or either drives have an option to include a power adapter or a second usb connector for power, I would highly recommend that those are used.
That may be "the clash" that we talked about in the clarification section.
Hope that helps,
cyan990
Jun 03, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie by stark external hard drive is suddenly not recognised by my computer (always worked until now) and has a permanent red light. Tried all usb ports and restarting computer. Whats wrong?
have you dropped it? it could be any number of disc errors, two of the most common errors are caused by viruses and dropping. try putting the hard drive in the freezer for a day or so in a moisture and static resistant bag. just a possibly remedy, if that doesn't work, try removing the casing on the hd and setting it as a secondary drive after you plug it inside a desktop computer.
May 09, 2011 | LaCie 500GB Starck Mobile USB 3.0 External...
I cant see my external lacie hard drive on my mac with the Lacie Network Assistant. The hard drive is visible with the finder though. With the dashboard and with the finder I am able to move or copy files...
for the product that you selected for your question, it is impossible for the LaCie Network Assistant to see it because it is a Local drive (USB).
The LaCie Network Assistant only detects the Network LaCie drives.
Regards,
Jan 25, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie starck hard drive is not recognised by new computer, running windows 7
You need to install some components like lacie desktop manager,intrergo etc that came with the original device
Look for them on lacie's webpage
GameSting
Jan 23, 2011 | LaCie Computers & Internet
I just bought my LaCie 301888KUA 1TB Starck Desktop USB2.0. I was following set up directions in the manual until I realized that my Mac OS X (version 10.5.8) is not recognizing the hard drive . It's not...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
Had this hard drive about 6 months it never moves from the spot i have it in out of no where it starts making a loud clicking noise and wont boot up ....what going on..?
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Jun 08, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Oct 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have a lacie design by F.A. Porsche 250Gig Hard drive - It has failed and is making a buzzing sound follwed by a beep - is this repairable?
Sounds like the hard drive in the Lacie has fauled.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32.
Sep 10, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
The computer does not detect the drive
check your hard drive jumper settings and also check your data cables. I assure if there is not a major fault then your problem will be solved.
Thank You
Jul 30, 2009 | LaCie 160GB Safe mobile 160 GB USB Hard...
LaCie Starck Mobile - hard drive - 320 GB - Hi-Speed USB USB 2.0 Logo
873 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
