Question about DeLonghi Heating & Cooling
I have a delonghi heater fire with pebbles - cannot see any ref no on it but it is stainless steel with 12 squares on the front below the pebbles and eight little squares each side of the bigger squares. The trouble is that when i turn it on it blows warm and then sudddenly blows cold and will not switch to warm again. I have tried cleaning it as it did this once before but when I got the dust out it wa OK again - but this time it isn't. Is this something an electrician could fix easily? what shall I do. This fire was bought from Argos about five years ago.
    Brigadier General:
  • 4,736 Answers
Cathy, since this is a recurring problem, it's best that you contact Delonghi Customer Care. In the USA call 800-322-3848. In Canada 888-335-6644. In Mexico 800-711-8805.
Posted on Mar 28, 2011
I am looking for a Delonghi P90d25 25L 900W Standard Stainless Steel Microwave manual
http://www.delonghi.com/en-us/customer-service/instruction-manuals
Go to the above website. It shows you the information you need to enter and you will have access to the manuals. They want the product number.
Good luck.
Semper Fi,
Z
Apr 26, 2017 | DeLonghi Microwave Ovens
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
How do I clean, what appears to be, rust marks on my stainless steel refrigerator
DO NOT use anything but a dedicated stainless steel cleaner. Some types of Windex have ammonia as one of the ingredients and you can imagine what that will do to your stainless steel finish.
Mar 23, 2014 | Samsung RFG297HDRS Stainless Steel
How do I replace the delonghi gran dama front light that displays the instructions. It is no longer working.
Wes...ours has the same problem. It's a 500$ part plus labour. Did you find a better solution?
Dec 07, 2011 | DeLonghi Esclusivo Gran Dama EASM6600...
Locating & lighting the pilpt
In the case of the Bosch type heater, the pilot light is just in front of and below the main burners. It is not easily seen because it is protected by a stainless steel wind shield. Look for the themocouple wire wich can be see pointing to the hole in the pilot jet.
Mar 19, 2010 | Water Heaters
I have a GE Side by Side Refrigerator. The
check your defrost heaters this is a common problem with ge ref you will have to take the back cover off you will see the heater towards the bottom some units have a double heater
Jul 03, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
NO HEAT
heating elements are located in the stainless steel tube attached to the control box. Older models from the early 1990's and 1980's were sometimes housed in a plastic case with a square 5 x 5 plate on the one end.
Jan 17, 2009 | RTO SPA SYSTEM HEATING ELEMENT - HEATER -...
Kenmore Elite refrigerator problem
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
TIMER-DEFROST (or may have a ADC)
Start with the timer. (if it has a ADC it will not apply) It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
Aug 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
DeLonghi Caffe Nabucco BCO70 Espresso &...
http://www.amazon.co.uk/JUG-GLASS-DELONGHI-COFFEE-MAKERS/dp/B000U1ABMQ/ref=sr_1_3/026-6359695-3226817?ie=UTF8&s=kitchen&qid=1191189017&sr=1-3 Try this URL Hope it helps
Sep 29, 2007 | DeLonghi Caffe Nabucco BCO70...
Heating & Cooling Logo
82 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
