Question about Tascam MD-801 rmkII Mini Disc Player
My Tascam md-801 r display goes of after 15 mins. If I switch off and leave it a while, it comes back on again.
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: power cut out on tascam x9
Since nothing else is working, the cooling fan is probably powered by AC at line voltage.
The power supply that feeds the electronics has failed but it may not be catastrophic; it might just be an internal fuse that has given up from metal fatigue.
Each time current flows when powered up, the delicate element expands and then contracts when the power is turned off.
Some fuses have a zig-zag crimp in the element that helps delay the eventual death.
With the unit unplugged, remove whatever screws you find on the back or bottom of the mixer so you can peer inside.
If you are lucky, you may find the fuse in a clip or otherwise plugged in.
There will definitely be one in the incoming AC line although if the fan is running, this one may be OK.
There could be one (or more) fuses on the DC side that directly services the circuitry.
Fuses come in a variety of cases; they can be cylindrical of glass or ceramic bodies with metal caps on the ends and of varying lengths.
Others may be vertically mounted smaller cylinders plugged into or soldered (bad) to the board.
Some are nearly indistinguishable in size and mounting from several other types of parts; these though, will not have other than simple text on the part while the others will have more complex markings.
If you find and replace fuses, buy two so that an eventual tech doesn't have to grub around to find one.
If you replace any fuses and they fail again, DON'T proceed. You may damage the unit further and not help anything.
At that point, you need to turn it over to a tech.
Posted on Jun 28, 2008
Diplomat Gas Oven cuts off after few mins
The oven is probably overheating and shutting itself off to prevent damage/fire. If the cooling fan isn't running. Check/replace the thermostat that switches the cooling fan on.
Aug 02, 2014 | Hotpoint Diplomat Oven Grill Selector...
Precor 9.35 won't stay on.
you must replace the control board electronic.
Go to www.treadmilldoctor.coa5bb443a-9b01-48c9-9230-29270afbdc24.gifm
and get it see the diagram how the control board control almost the 80% of the machine.
God bless you
Sep 18, 2013 | Precor Exercise & Fitness
Tascam MD CD1 MK2 / TOC Reading on my cd drive
I would consult New Jersey Factory Service- It sound like you might need a new CD module. Russ can tell you about those.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
www.njfactoryservice.com
Dec 01, 2012 | Audio Players & Recorders
TASCAM MD350 After a couple of minutes in Record or Playback mode the machine switches off (display extinguishes). A while later it comes back on and starts playing the 1st track. This happens with...
Very strange- It sound like a thermal break int he soldering somewhere.
Either that or an intermittent short in a capacitor. I suspect that the problem will be back.
Jul 11, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
Sound problem on TV monitor L 2010
What are you using to connect to the monitor? Have you tried replacing the cable, sometimes cheaper HDMI cables can cause this issue
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Feb 07, 2018 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Mid2020
if this is a desktop: Did you check the power supply? try to replace it with a new one
Laptop: Try to run the machine without the battery plugged in....straight with the adapter....If the laptop still restarts...it's a manufacturing defect which should be replaced by the OEM.
Jan 14, 2008 | Medion MD-40954 Notebook
Medion Mid2020 MD-41060 Switches self off
Probably....overheating. Maybe....the CPU fan or chassis fan(s) need to be replaced. Or...perhaps...the thermal sensor on the Motherboard is failing.
Jan 11, 2008 | Medion MD-40954 Notebook
Tascam MD-801 rmkII Mini Disc Player Logo
103 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
