Hello
What is the brand name ane model number of your DVD? Inform me these by Fixya please.
Hello Jose
Some otheres has also posted solutions to this problem I can see.
[1] Go into the Home Menu
next go to manufacturers lock {in settings} but do not go across on the menu to enter the 4 figure code.
Input {numeric} 0000000 then enter .The display on the tele will come up saying Congratulations .
[2]download http://aiwaownersnetwork.tripod.com/page...
then burn it on a CD-R
put the CD in the player and then a menue pops up and you can choose the region code. "0" is free.
[3] 1) Power On
2) Open Tray
3) Press Home
4) Enter "Set up" menu
5) Highlight the Lock Picture (Don't Enter Right hand Menu)
5) Press "0" seven times
6) You should now have a message on the screen saying "This player is now Region Free".
Hi, To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the "SETUP" button on remote control,
then select the "Preference MENU"
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
Region
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select "0" setting = Region Free (confidential)
You can also use the link below to know more about region.
http://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
and
http://hometheater.about.com/cs/dvdlaserdisc/a/aaregioncodesa.htm
Hello Jose,
Although the solutions listed were from 2008, no firmware updates were issued for this player. The seven zeroes code should work for your player, unless you bought a later version of the player with different firmware for which this unlock code doesn't work. I'm not aware of any later versions.
I would advise you to try again and follow my instructions below very carefully. Sometimes the instructions given for unlocking DVD players are badly explained and/or miss a vital step.
LG DR389 Region Code / Hack
1. Switch on the TV and DVD recorder
2. Switch the TV to the correct input for the DVD player
3. OPEN the disc tray (and leave it open)
4. Press HOME on the LG remote
5. Open the SETUP menu
6. Highlight the PADLOCK icon but do not press the right arrow / enter the right side of the menu.
7. Enter 0 0 0 0 0 0 0 (seven zeroes)
A message should display on the TV screen to say "This player is now Region Free"
8. Switch the player to STANDBY/OFF (don't unplug it) then power on again.
It may take a couple off attempts to unlock the player. If it doesn't work, switch the player off, go back to step 1 and start again. If you are still unable to unlock your player, please let me know and I'll check for any other known unlock methods for this player.
Regards,
BElectric
Jose -
The seven zeroes code is the unlock method for this player. There are no other region hacks. If it doesn't work, you are either not doing it correctly, or you have a player with updated firmware and your player cannot be unlocked.
Not all players can be unlocked.
Gopakumarg -
The model number is there. It's been there for 4 weeks. Please try unlocking questions before answering as this will allow you to see any comments which have been posted.
Hi, well what you can do for SOME DVD is one can get a Region Code Hack, that will allow one to do as you wish. However NOT all players can be changed.
http://www.videohelp.com/dvdhacks
This link above will allow you to get a code if there are any, also one can use Google and ask for a hack, simply Google name and model and the words region code hack, and see if there are any?
My LG DR389 is set for region 2 and I want to extend to Region 1. I Have tried the 7 zeros proposal but it didn't work.
Your help is appreciated.
Jose Leal
For my LG DR389, that I just bought, the solutions provived, dated from 2008, and using the 7 zero key, didn't work on my DVD which is built for Region 2. I am looking for campatibility for Region 1,
Regards
The received advice is insufficient and I need another one. I Paid for it:
Regards
Jose Leal
My LG DR389 is set for region 2 and I want to extend to Region 1. Thks in advance
Jose Leal
