Question about HP Computers & Internet
How do i switch off the display only - HP Computers & Internet
  • 368 Answers
Glad to HELP YOU!
It's easy...
Right-click on the desktop anywhere you want. Select PROPERTIES > ADJUST DISPLAY SETTINGS (or just DISPLAY SETTINGS - it depends what kind of operating system you do have) > CHANGE POWER SETTINGS > and select CHOOSE WHEN TO TURN OFF THE DISPLAY and after that select a desired time.
Make sure once you're done with that that the options (the similar ones) for the HARD DISK are NEVER.
My best regards!
Posted on Mar 28, 2011
Mercedes benz 2004 vito 111 fog lights not working front only come on when switch is in rear position but no rear fogs i have checked all fuses is there any way to check switch ?
The only way to test the switch is to take it out of the dashboard and disconnect it.
Using a multimeter set to continuity, (yellow circle), or Ohm's, (Green circle), place the black probe to one terminal and the red to another. Move the red to each of the other terminals in turn watching the meter display. Move the black probe and repeat moving the red probe. Do this for all the terminals on the switch, in all of the switches positions.
If the switch position is working you will get either a tone or numbers on the display. If the switch position is closed OR faulty you will not get a tone and the display will show 'O.L' (means open line).
The off position will always give you no tone, ( displays O.L) . A single action switch will give you only one pair of terminals as a tone, (displays numbers). A twin switch will give you two pairs of terminals as a tone, (displays numbers).
Feb 15, 2018 | Mercedes-Benz Cars & Trucks
How Do I program the hpm digital time switch hl 03705 Eco Rex d11
How to Program HL 03705 EcoRex D11 Timer
The "switch" is a small rod which can be moved 5 ways - left, right, up, down and IN.
Before programming check that time and date are correct.
Time - push switch IN, then down once until TIME flashes on display. Push switch IN, then up or down continually to select hour, then switch IN, then up or down continually to select minute. Push switch IN to save.
Date - push switch IN, then down twice until DATE flashes on display. Push switch IN, then up or down continually to select year, then push switch IN, then up or down continually to select month, push switch IN, then up or down continually to select day. Push switch IN to save.
Programming - for the sake of this exercise the timer will be set to come ON at 7am and OFF at 10pm, 7 days of the week.
Note the numbers 1234567 printed just above the display window. These represent the days of the week, starting with Monday.
1. Push switch IN, then down four times until PROG flashes on display. Push switch IN. The display shows a vertical line with numbers, at the bottom of which is a digital time which should show 0:00. This is midnight, Sunday to Monday.
2. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Monday and will be the first ON time. (Push switch to the left to change minutes, each push advances time by 1 minute).
3. Now push switch to the right and HOLD there. BE PATIENT! It takes several seconds before the time changes, firstly a minute at a time, then in 15 minute blocks. Still holding the switch to the right watch the digital time display advance (don't look at the vertical line which has another thick line develop beside it as the time changes!) until it reaches 22:00, then release switch. This is the OFF time, 10pm Monday.
4. Push switch up once, this advances the time 1 hour. Continue to push switch up, one hour at a time until the digital display shows 7:00. This is 7am Tuesday and will be the next ON time. (Push switch to the left to change minutes, each push advances time by 1 minute). Note that there is a small dot under the number 2 at the top of the display to indicate it is Tuesday.
5. Now push switch to the right and HOLD there. Still holding the switch to the right watch the digital time display advance until it reaches 22:00, then release switch. This is the next OFF time, 10pm Tuesday.
6. Continue the steps #2 and #3 through Wednesday to Sunday. You will know when you are back to Monday by looking at the dot at the top of the screen returning to be under the number 1, OR when you return to 7am Monday there will be a thickening of the vertical line starting at 7:00.
7. PUSH THE SWITCH IN TO SAVE THE PROGRAM.
Testing - To check the program settings - push switch IN, then down five times until TEST flashes on display. Push switch IN.
Each upward push of the switch moves the display through each subsequent ON and OFF change. Check the day for each ON and OFF by viewing the dot under the numbers 1234567. After the last ON/OFF change the display shows PROG END.
Operating the Program
Push switch IN, then down six times until AUTO flashes on display. Push switch IN. The device now operates on the times that were programmed. The display returns to the "home" view, showing the current time, also vertical strips lined up under the numbers 1234567, representing the times of operation each day.
Outside the display window, at the bottom of it, the words OFF and ON are printed to the left and right respectively. A cursor points to one of these to show the current status of the device.
To bypass the program - push switch IN, then down past AUTO until ON or the next one, OFF, flashes on display. Push switch IN - at ON to have device permanently switched on or at OFF for device permanently switched off.
Feb 04, 2015 | Hardware & Accessories
Set clock
Turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
May 02, 2014 | 2008 Harley Davidson FXDWG Dyna Wide Glide
Set clock 08 fxdwg
May 02, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
How to reset clock on 2010 softail deluxe?
Apr 26, 2014 | Harley Davidson FLSTN- FLSTNI Softail...
How to change language English
You can find the manual for the Jura IMPRESSA S9 One Touch at the link below. I have typed the Instructions from the Owner Manual Below. See: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Program Language:
Example: To change the language from ENGLISH to DEUTSCH (example), proceed as follows.
Precondition: COFFEE READY is displayed
  1. Keep the Rotary Switch pressed until MAINTENANCE appears.
  2. Turn the Rotary Switch until LANGUAGE ENGLISH is displayed.
  3. Press the Rotary Switch to enter the programme item. LANGUAGE ENGLISH
  4. Turn the Rotary Switch until SPRACHE DEUTSCH (example) is displayed.
  5. Press the Rotary Switch to confirm the setting. GESPEICHERT (example) appears briefly on the display. SPRACHE DEUTSCH (example)
  6. Turn the Rotary Switch until EXIT is displayed.
  7. Press the Rotary Switch to exit programming mode. BITTE WAHLEN (example).
Best of Luck!
Jan 14, 2013 | Jura Impressa S9 One Touch
How do you set the clock on a 2008 harley dyna super glide on the speedometer?
FOR 2009 turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
Jul 30, 2011 | Harley Davidson FXD Dyna Super Glide...
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Mar 25, 2011 | IOGear GCS634U KVM Switch
How do I reset the computers timing belt information in a Toyota 2007 4.7L (VIN T, 5th digit, 2UZFE eng, 8 cyl) after making a timing belt change?
1. T-BELT MODE DISPLAY
a) With ignition turned ON, using the trip switch (select/reset button) change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display "15" (0,000km) is displayed (ie. 150,000km).
2. REWRITING REPLACEMENT VALUES
While in the T-Belt mode, each press of the trip switch will change the displayed value by 10,000km increments. Once " 20 " (200,000km) is reached the display reverts back to " 1 " (10,000km) again. Remember, this setting is the number of kilometres to be travelled before the light comes on next, and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is 150,000km, but this should be checked against each different markets servicing recommendation. This being the case, you shouldn't need to change from the default setting of "15".
Obviously for the US, the ODO is in miles, and I guess the T-Belt warning would be set in 10,000 mile intervals.
3. T-BELT WARNING RESET COMPLETION
a) After setting the replacement setting value, hold the trip switch ON for more than 5 seconds then release the switch.
b) Check that the display has now changed back to ODO and that the warning light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has not been performed, the T-Belt warning IS reset.
Oct 30, 2010 | Toyota Tundra Cars & Trucks
My Nokia 7610 Display is white after switch on
display problem change the display
Dec 06, 2008 | Nokia 1100
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
