Question about Nintendo DS Console
Sound problem sound is not working for some games, unless I use headset which is fine. I needed to replace case as hinge was broken and since doing this sound has gone. in particular star wars the complete saga, there is no sound unless you put your ear right onto the speaker, (you have to be in a quiet room). but the sound effects work ok??. I have checked the volume in options and it is set to the highest level. can you help
    Scholar:
  • 168 Answers
When you put it back together the volume selector (on the board) was all the way to the right and the volume slider (on the case) was all the way to the left which won't allow you to turn the volume up all the way. if this is not the case let me know @
ninja_freak318@hotmail.com
and I will assist you further
Posted on Dec 17, 2008
Hinges broken, power supply borken, bottom case replace
And you question is? Sounds like you need a new laptop.
Feb 27, 2013 | Computers & Internet
My Plantronics Gamecom 367 headset has a problem with the mic. For some odd reason the mic will not pick up my voice, or for that matter any sound that is supposed to be detected by it. Instead it gives me...
Sounds like there might be a broken wire (shorting out by touching something else) or something loose in the mic area. This could still be under warranty with Plantronic's. If it is you should be able to have it replaced.
Good luck from Headsets Direct!
Jan 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
My ds lite is broken from the hinges
You need a new case, fiddling with it whilst the hinges are broken can lead to broken top screen speakers/mic and wifi capability
Cases are on ebay and various other web sites for 10-20
Dec 08, 2009 | Nintendo DS Lite
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
Jan 22, 2009 | Nintendo DS Lite Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Fualt on DS
By putting the case together you've short circuit the black wire with the powerconnector. Open the bottom case and check the wire. Check Fuses F1 and F2. 99,9% change that one of them is blown out. Replacements can be found on the Internet
Aug 14, 2008 | Nintendo DS Lite Console
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
Broken top screen (original DS)
Replying to the first post:
If you have broken the ribbon cable, which is highly likely if you have broken the hinge, then the DS will not work. It does not turn on unless there is a connection to both screens. You will need to buy a new ribbon cable for it:
A useful site I found is: www.consoleparts4u.co.uk
Once you replace this then it should work for you.
Repling to th second post:
I would recommend buying a new case for it at least because the ribbon cable will break if left broken due to the strain on it.
The more expensive but easier option is to buy a new one.
Hope this helps,
Mowcius
Jun 16, 2008 | Nintendo DS Console
Ds lite hinge broken right h/s (looking at it)this has affected the top screen any ideas please
Hi, it sounds like when the hinge has got damaged, so has the top screen ribbon on the left as its easily ripped. Would need a replacement case and top screen, can recommend here for both: www.console-spares.co.uk, hope this helps.
Mar 24, 2008 | Nintendo DS Lite Console
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
Nintendo DS Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
