Question about Samsung B5722 Cell Phone
I cannot able to see videou file full screen - Samsung B5722 Cell Phone
    President:
  • 1,118 Answers
Convert ur video revolution into 320x240 dim it will disp in full screen
Posted on Mar 28, 2011
What is the problem on recording my fourth record, the screen indicates FULL. What is the next step. Thank you
When you say "fourth record" do you mean 4 LPS containing at least 16 tracks each?
If you are, check the format that the recordings are in. For example some recording software use WAV files which are very large.
Since an LP is about 30 minutes a side maximum you could have two hours of music! Depending on how full you drive was it could be nearly full, especially if they were recorded as WAV files!
MP3 files take up far less space so you could convert the WAV files to that format and then delete the wave files. If you can free up space to do it.
Jun 25, 2016 | Audio Players & Recorders
How do I get my prtscn to print straight
Instructions
  1. Use PrintKey2000 to Direct Print
    • 1Download and save PrintKey2000 or PrintKeyPro from the "Resources" section. Save the file in a folder named "Printkey" on your "C:" drive. Double click the .exe file and follow the onscreen instructions for a problem-free installation.
    • 2 Access the Print Key program by double-clicking the hand icon in the bottom right hand corner of the task bar.
    • 3 Double click the "Options" tab in the upper right hand corner. Click on "Define Hot-keys." Set a hotkey for printing the full desktop and for printing the active screen you are in.
    • 4 Navigate back to the "Options" tab and select "Direct Print (No Dialog)" so that it has a check mark next to it.
    • 5 Select the "Printer Options" function on the main program screen. Select the printer you want the print jobs sent to.
    • 6 Select a screen to use as a test. Press your hotkey for printing the full desktop and then the hotkey to print the active page. You want to make sure both functions work properly.
    Use the Print Screen Function Without a Plug-in Program
    • 7 Press the "Print Screen" key on the keyboard to print the full desktop. Press the "Alt" key plus the "Print Screen" key to print the active window.
    • 8 Click "Start" in the lower left of the taskbar. Navigate to "Applications" and choose the Microsoft Paint program.
    • 9 Click "Edit" in the program screen and click the "Paste" option. You will now see a copy of your screen capture.
    • 10 Navigate to "File" and save the screen capture as a .jpeg file. Navigate to "File" again and click "Print" to send the job to an installed printer.
    Using the Print Key Function with ScreenShot 2 Print
    • 11 Download and install ScreenShot 2 Print. ScreenShot 2 Print has a free trial option, and as of May 2010, costs $7 for the full version. Configure the program to print to a designated printer from the onscreen commands. The screen captures will print automatically when the required keys are pressed.
    • 12 Hold down the "Control" key (Ctrl) and the "Print Screen" key to capture a screen shot of the full desktop. The image will be sent directly to the designated printer.
    • 13 Hold down the "Shift" key and "Print Screen" key to take a screen shot of the active window, which is sent directly to the printer.
May 21, 2014 | Microsoft Computers & Internet
Touch screen has stoped working anf wont let me go on to menu to delete files because the memory is full happened sinse the memory filled up sony dcr-sx50e
Well that sounds like obvious... put the cable in to your computer and delete the files that you want to. If you can't use the "touch screen" and get full access to the camera's files, then plug the cable on your camera and computer and then access the folder and delete your files.
I hope I helped in something.
Nov 12, 2010 | Sony DSC-T70 Digital Camera
Full memory
Delete all file incoming msg, draft, or save msg, during Bluetooth image of file transferring. Phone memory full already, better save incoming msg or receive file through Bluetooth to your memory card, don't save on memory phone.
Jul 29, 2010 | Nokia 7610
While trying to change settings on my computer I lost the Browser bar ie. file, edit, bookmark, icon for home forward and back feature, address bar
Most probably you pressed the F11 key in the upper key row on your keyboard, and it entered "full screen" mode.
Press F11 to exit full screen mode, this should do the trick.
If this is not the case, please come back and write a comment to that effect, we'll try to assist you further.
Good luck :)
Jul 10, 2010 | Gateway MT3705 Notebook
In Youtube, when I click full screen, the screen turns blank.
you just right click and select a particular file for ex media player
so that u will able to view it
Mar 21, 2009 | Gateway MT6729 Notebook
Cant get landscape mode to work on dash
Hi jnesbitt1,
Full screen usually only works for video. A few questions:
1) Are you watching video or is this a music file?
2) Have you tried pressing the zero key/button while the file is playing?
- If so, do you see any error messages?
- Does the screen change, flash, or flicker?
Please respond to the question above when you have an opportunity and we'll take things from there.
Thanks!
The MoDev Kid
Sep 28, 2008 | T-Mobile Dash Smartphone
Turbo c/c++ not working in full screen mode
The problem the dos is not compatible with windows xp.Right the launcher file and select properties->screen->select window(i.e deselect full screen) now the program will launch hopefully,it worked for me. now go to full screen by pressing alt+enter.
Aug 20, 2008 | Dell Inspiron 1501 Notebook
File storage is full
here is the manual, look at page 9 of the e-manual for the function keys.
# 9 Edit file mode ----Print file. ( also shown on pge 81)
shows how to delete the file also.
Good luck
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=412914c5b54b5add014416140dfd72ec&q=panasonic+uf+585+manual
Sep 19, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
Media Player 9 on ipaq hx4700
The 4700 has a 480 x 640 pixels display and WMP9 will not compensate for the smaller resolution videosthus the less than full screen size play back on video with less than the 480 x 640 pixels size resolution. There is a program that will play the smaller res. videos in full screen on your PDA try TCPMP its free, go here: http://corecodec.org/projects/tcpmp
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Samsung B5722 Cell Phone Logo
105 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
