Question about Nintendo Wii Console
When i put the wii on, the standby light comes on but when you press power the system is dead
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 211 Answers
Your system has corrupted:(
You have to reinstall the firmware of the wii!
How?Look at Youtube
Posted on Mar 28, 2011
  • keiths131 Mar 28, 2011
    Sorry this is for a wii with homebrew games I don't have that channel. My issue is power related when my standby light is on and i press power on or eject disc I get a quick flash of the blue light from the disc then the power light goes out!
Wii has no power whatsoever going in
The button has to be pressed until you see the light come on try using the wimote power button on the upper left corner hold it until you see the light if its yellow its in standby if its green its on you should see the disk entry area turn blue a sec when it comes on. Then it should be green on the power light if no lights in just a couple or 3 seconds holding it down you may have 2 bad wii's in a row. If you take it back ask them if they have a test model on the floor and tell them to show you exactly how it works to power on and off.
Dec 02, 2011 | Nintendo Wii Console
WII DOES NOT TURN ON AT THE POWER BUTTON
remove the power cord from the wii. hold the power button in for 15 seconds.
plug the power back in. if the power light comes on check the color.
green is on, yellow is standby and red is totally off.
if there is a light press the power button and see if it turns on. if it does not then from a Wiimote, press and hold the power button on the remote. this should turn the console on. if the console does not turn on and the remote batteries are good you can try one more thing IF the light is on.
press and hold the reset button for 10 seconds on the system. disconnect power and replug. if you still cannot turn it on then your system is bricked or damaged and needs replacement.
in any case the power button is broken you can turn the console on and off from any remote
Aug 24, 2011 | Nintendo Wii Console
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
My Wii is all plugged in but the light is out like its unplugged. we keep unplugging and plugging it back in but it is still not working, how do I fix this?
I think you are asking about the slot illumination for the wii this is how you change it:
  1. Access the Wii System Settings.
  2. Move the cursor over the blue arrow on the right and and select it once to reach System Settings 2.
  3. Choose "WiiConnect24."
The following options will be available:
  • WiiConnect24
  • Standby Connection
  • Slot Illumination
Choose Slot Illumination
Slot Illumination (Bright, Dim, and Off)
WiiConnect24 can let you know when it has received data by making the Wii console's Disc Slot illuminate. Select the option you want, then confirm your selection.
Bright: The Wii's Disc Slot will display a bright blue light when WiiConnect24 has received new data.
Dim: The Wii's Disc Slot will display a dim blue light when WiiConnect24 has received new data.
Off: The Wii's Disc Slot will not blink when WiiConnect24 has received new data.
Feb 27, 2011 | Nintendo Wii Console
My power light turns yellow instead of red i have to hold thepower botten to make it red
With the Wii system, when you hit the power button, it goes into Standby mode. That is the yellow light. In standby mode, the system draws a little bit of power, and it will go into a ready to play state faster than when Off. Holding the power button FULLY powers off the Wii system, and that will give you the red light. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
WHEN I PUT MY CONTROLLER ON ALL IY DID IS BLINKED.I
Change the batteries. When you press a button the 4 lights on the bottom will light up corresponding to how much power is left. One light usually means it's dead. Otherwise clarify the problem, using puncuation.
Aug 01, 2009 | Nintendo Wii Console
Wii consol
Sounds like a bad ac adapter. You should buy a replacement.
Oct 27, 2008 | Nintendo Wii Console
Wont go onto standby.
When you press power ( on the wii itself), keep holding the power button for 4-5 second and it should go to standby mode, front led shines RED. :)
Oct 06, 2008 | Nintendo Wii Console
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Wii Power, Wii Goes Dead when I press Power or Eject Button or Remote Power Button. Is THIS AN INTERNAL DAMAGE
According to Nintendo u can try this. 1. push the reset button and if that doesn't work unplug all cords and memory cards (including sd) from wii and unplug av from the wii and the outlet in wall. Wait 2-3 min and then plug it back in. Thats as far as i got because that fixed my problem hope this helps someone!!!
Jan 15, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
