Question about Whirlpool Washing Machines
Hello, I have an whirlpool machine AWM 6105 and this morning when I started the washing program it gave me FH error. I stop it and start again and it worked. what thoes this error means? can you give me an list with the error codes for this machine type? Thanks in advance, Claudia
    Brigadier General:
  • 6,277 Answers
'FH' for Whirlpool decodes as 'no water fill'. Providing that the taps are fully on, the hoses are not kinked or squashed, I suspect this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Also do you need a manual? I have to assume that most manuals have the decodes in them.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 28, 2011
Whirlpool awm 9000 I bought a used Whirlpool
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Oct 18, 2013 | Washing Machines
I have a whirlpool that whithin a few minutes of starting the wash it stops with a HF code. I restart it again and it does it again. What do I have to do? Please help!!!
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Aug 26, 2011 | Whirlpool WFW8300SW
Program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
May 04, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Feb 07, 2009 | Whirlpool AWM8123 Front Load Washer
My duet washing machine throughs out a FH code
FH is a water inlet related issue, make sure your cold water supply is working correctly, sounds as if its trying to rinse(cold water) and has no water to do it
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves
will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow sensor has
detected 48liters of water passing through it, but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash.
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
255 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
