Question about Pelco DF8CB Pg 1V21A Domepak Pendant Color 2.812mm Ai
THE DOME CAMERA MODEL KDSQOOP1 (ULTRAK) IS STUCK ON ONE POSITION WITHOUT ROTATING EVEN IF YOU USE THE JOY STICK. wHAT IS THE PROBLEM?
    Problem Solver:
  • 5 Answers
If the problem is not hardware related than its likely your missing a software update. You can find the software updates on Pelco's website or trouble shoot with fellow techies & tech support at www.pelco.com/community - doubt your still going at it after a year but good information never hurt :)
Posted on Oct 26, 2012
Loader stuck in down position, the joy stick will not raise or lower loader. The joy stick will work the tilt movme
didnt specify type of machine( generic answer)some machines have an electrical assist joy stick check switchs if hydraulic check the r check fluid level in the hydraulics the tilt uses less fluid to the piston than the lift arms ----check the hydro lines and connections doesnt happen all the time but try bleeding lift lines air or debris in lines
Sep 15, 2015 | Cars & Trucks
Dome light won t turn off
can you give more details pls. does it urns off even with the door shut?if not the switch itself on the dome is stuck to on position try removing it and clean it
Mar 20, 2014 | Mitsubishi Cars & Trucks
Dome light switch on 1993 Honda Accord
check to see if button on door frame is stuck they get dirty and stick sometimes also check to make sure dome switch is in right position
Jan 10, 2013 | 1993 Honda Accord
My ps3 controllors left thumb joy stick gets stuck in the direction i push it in. It does not go back to its standard position unless i manually move it myself. i think it is just worn out but any...
This too happened to me before. What I found that if I repeatedly clicked the stick in, and slightly tugged on it, it would keep the stick from staying stuck in the one position. Hope this little trick works for you as well!
Mar 07, 2011 | Sony Wireless Controller for PlayStation 3
Ultrak kc550bcn product manual
does anyone have an operating manual for an ultrak cctv color camera model KC550BCN
Jun 20, 2009 | Cameras
Why the Pelco spectro mini PTZ camera getting stuck(not rotating)
Normallay when getting stuck in Mini dome, we found 2 common problem.
1. Take out the cover and test rotating. Dome are deflect and causing resistance between camera dome and bubble.
2. The 2 screw are too tight. Loosen abit and try rotate.
Jun 03, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Is there a way to transfer pictures from internal memory to memory card without a usb cable
push menu when you are on any picture, go to copy with joy stick,push joy stick straight down ,it says copy to memory card, picture or exit or all.
Dec 02, 2008 | Kodak EasyShare Z650 Digital Camera
C:13:01
Is the camera under warranty. If it is, we need to change it for you. The second thing to remember there is that if the camera needs to be opened, don't do it yourself. Take it to a professional.
Jun 08, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Mamiya RB67 ProS wont trigger or advance
Start by making sure the dark slide is removed, the camera will not fire with it in place. The next step is to check the rotating back to make sure it is locked in either the vertical or horizontal position. Without film in the magazine, the multi-exp lever on the back must be set to show the red dot under the advance lever. You can check the camera without the back by removing the rotating back using the latch on the bottom of the camera
Nov 25, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Pelco DF8CB Pg 1V21A Domepak Pendant Color 2.812mm Ai Logo
199 people viewed this question
Top Pelco Home Security Experts
bobby euell
Level 1 Expert
Leon Peach
Leon Peach
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Pelco Home Security Expert? Answer questions, earn points and help others
