Question about Bosch Dishwashers
We took the dishwasher out because it wasn't working. Mechanical fault is fixed but the machine won't go quite back to the screw holes to fix it back in the casing and we can't see anything blocking the way or why this is happening. Any advice?
    Master:
  • 354 Answers
Thats the life of a mechanic you just have to possibly start over ,paying attention to the alignment and you will find it about half way through it that is usually how it works. Then we can call you an expert thats the learning curve on all things.
Posted on Mar 28, 2011
F70 fault
Obviously the machine believes the drain cycle is not complete. It is running the drain pump until the level it "sees" is all the way down. Somehow you or your technician will need to get inside the beautiful stainless panels to adjust, clean or replace the drain level sensor...
Dec 27, 2012 | Miele G 2630 SCi Stainless Steel Built-in...
I have an oakley minute machine. Last week i went to a shop to replace my batter, after about 15 mins. i went back to the shop to pick it up. The repairman told me that the hour hand wasn't working and...
You should not even be thinking of fixing the watch yourself!
The problem, and the responsibility for remedying it lie solely with the repair man. If your watch was not broken, and only in need of a new battery when you took it in, then the fault is entirely caused by them.
Take it back to them and demand that they re-instate it to good working order.
Oct 07, 2017 | Watches
My Brother XL5130 Needle Clamp Body felt out while I am sewing something. I do not know what is missing. I found 4 things in my hand Clamp Body, Pin,Clamp side screw & threads guide. some one plea
There is a hidden screw just that looks like a hole beside the screw that hold the needle... loosen it with # 8 allen key (pretty small) then you put the curved wire back in its hole, then you can put it back on the arm, then screw back the allen screw as tight as you can, this should do the trick worked for me ... I was tring for days to fix it back on but wouldnt go in...this invisible screw was to tight... Hope it helped !
Jul 19, 2012 | Brother XL-5130 Mechanical Sewing Machine
A screw fell inside the tub I took the bottom sreen apart it was uder the base were the impeller is, took that apart, put everthing back together and went to start the dishwasher up and the LE code...
try this. I have a similar problem and now have the LE code flashing. I saw this advice and am going to try the fix now.
You are barking up the wrong tree. Here is the real fix for the LE problem.First disconnect all power ( power supply, circuit breaker, wiring etc) to the machine. Disconnect all tubing to the machine ( drainage pipe and braided hose feed) Then you need to take out the dishwasher, turn it over and then remove the large white sensor tray that will expose the leakage sensor held on by 2 screws. Remove the screws and dry up the sensor tips (4) with a dry towel and dry up the tray all around as well. Replace the tray and re connect all tubing and power. You're problem should be solved and you just saved yourself a pile of money in service repair bill. M.D.
Dec 22, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
I took my machine apart to correct a problem and I'm looking for help reassembling the machine. I really just need to know where the screws go.
depending on how far apart you took it you may need to take it to a service technician. if its only the cover plates the newer machines usually only have screw holes on the back of the machine and usually under the handle.
Nov 06, 2010 | Brother XL-2230 Mechanical Sewing Machine
I have a Bosch Dishwasher SHE58C05UC. It has suddenly quit draining. I can't afford a repairman so I need to try to fix it myself. Can anyone please help? Thank you.
OK lets give it a try. First remove the bottom panels of the dishwasher. These panels are located below the door right at the floor. There should be two 1/4 inch phillips #2 head screws. Once the panels have been removed you should be looking at the floor and the underneath of the bottom of the dishwasher. Now here's where it gets tricky. There is a impeller motor you should be looking at. It is round and usually black in color. This motor is activated when the dishwasher goes into drain cycle. The back of this motor should be facing you as you look at it and it has several vent holes at the point facing you. These vent holes will possibly have quite a bit of dust and debris on them so you may not see them at first (this is quite normal on these types of motors since they are cooled though these vent holes. Take a cheap paint brush and brush off any debris on the back . You will need a flashlight to see the fins that are just beyond the vent holes (you need too look into the motor itself through these vent holes) There are a numerous amount of fins located in the back of this motor. Now using the flashlight and looking through the vent holes at the fins activate your dishwasher(do not put your hands under the dishwasher while on Very Important) Now if you can manually advance the cycles to drain do so at this point, if not, you need to wait for the drain cycle. Once the drain cycle activates you will hear a click from a electrically activated selinoid. If you do not hear this click and see the arm on the selinoid move then this part needs replacement. Take model and serial # off machine to a parts house for replacement (usually around 18 U.S.D.) If you see and hear the activation of this switch then look at the fins at the back of the motor they should be spinning. If not, turn off the dishwasher and unplug it. Once this is done take a small screwdriver, slotted or flat head whichever you prefer place it in the back of the motor and gently push one of the fins through the slot counterclockwise this should unfreeze the impeller and if it spins freely when you move the fin with the screwdriver replug it back in and see if the problem is corrected. If the fins refuse to release then the impeller is froze up and a new drain motor will need to be purchased. This can be a little pricey so call an appliance parts house first before heading out there to get one.
I sure hope this helped you cause it took forever to type
Good luck on it
Dr Berry
Feb 16, 2010 | Dishwashers
Dishwasher gets part way through cycle then t
I took the bottom cover panel off even though there was another panel behind it the plastic tray nderneath was full of waste water. I took the 2nd panel off and found that a rubber cap attached to the waste pump has a hole in it, I got the replacement part for $5.00AU and the dishwasher is now working fine.
Dec 15, 2009 | Electrolux Dishwashers
Leaks from bottom
Pull service panel at base of dish washer and tell me if water is underneath. Should read owners manuel if you have it. most likely leaking from where it connects to kitchen sink or a loose drain hose under the unit. Easy fix if this us the true problem
May 28, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Apr 06, 2009 | Asko 24 in. D3121XL Free-standing...
Neff dishwasher removal
this may work - if it is an integrated dishwasher you should have a star shaped screw attaching the door to the machine on either side (about half way down). try pulling the machine out - and then looking for the holes on either side at the front. insert a star screw driver (may not work with other screwdrivers) and release the bolts (screws) then slide the door upwards.
Jan 17, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
