Question about HEWLETT-PACKARD Hewlett Packard HP Mini 5102 10.1-Inch Netbook (Black) (FN099UTABA)
Hp mini 110 problem screen black mouse blinking
Hp mini black screen w/ cursor blinking
Sounds like the hard drive isn't working. check in the setup bios of the machine to make sure it is recognized as the main boot device. It should be second in order so that a flash drive could start it up if plugged in. It would be third if you have a CD which minis usually don't. If it lost the date/time and settings, the backup battery is bad and needs replaced.
Mar 13, 2013 | HP Mini Computers & Internet
Hey I'm having troubles with my compaq mini hp 110
Sounds like the operating system is not loading. needs to be reinstalled.
Jan 24, 2013 | Computers & Internet
Hp mini 110 screen fliclers if cursor moved to top of screen
Video drivers ? Reinstall them ? Does same thing happens on external monitor ?
Nov 20, 2012 | HP Mini 110-1037NR Netbook
Recover windows 7 mini 110 3130nr
take the big battery out first?
if F11 is dead that means, HDD bad, or corrupted.
reload from HP recovery media at HP, we are NOT HP.
it came new with W7 and never changed?
Sep 02, 2017 | HP XH021UA 110-3130nr Mini Netbook PC -...
My HP Mini 110 touchpad mouse is frozen. Pls help
Hello
If the touchpad does not responds then make sure that the touchpad lock switch (just above the touchpad) is not turned off.
If this doesn't work,Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load) You should see a menu "Select Last Known Good Configuration" and press Enter.This should solve the problem if not,try to download the synaptics drivers for any of the Mini 1000 series laptop edition as you have a Mini 110. It does works.
Apr 12, 2011 | HP Computers & Internet
HP Mini 110: When the power swich is pressed, The system doesn't turn on (no fan operation) and the power light blinks.
Looks like your power adaptor needs replacing if your getting no charge. Make sure the plugs are in tight and replace the fuse in the plug as well in case.
Sep 06, 2010 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
Black screen wont boot little blinking dash left hand upper coner
One Blink repeating. >>CPU not functional.
Two Blinks repeating.>> BIOS corrupted.
Three Blinks repeating.>>RAM Module Error.
Four Blinks repeating.>> Graphics Card Failure.
Five Blinks repeating.>>Other Systemboard failure.
Six Blinks repeating. >>BIOS authentication failure.
Jul 19, 2010 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
The screen on my hp mini 110 went white
A white LCD screen can be caused by (likeliness):
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard.
A local computer repair store should be able to fix this for you.
Jun 25, 2010 | HP Mini 110-1037NR Netbook
HEWLETT-PACKARD Hewlett Packard HP Mini 5102 10.1-Inch Netbook (Black) (FN099UTABA) Logo
61 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Marvin
Marvin
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
