Question about TP-LINK TL-SF1008D 8-Port Ethernet Switch
How to setup my tl-sf1008d in my computer with other computer to play lan games with no internet..
  • 4 Answers
ASALAM
CONNECT BOTH PC WITH CROSSOVER WIRE OR MORE THEN TWO PCS THEN ADD SWITCH LIKE TPLINK WITH STRAIGHT WIRE
LOOPBACK ADOPTER SHOWS LOGICAL CONNECTIVITY BETWEEN DIFFERENT COMPUTERTS WITHOUT INERNET
ON 1ST COMPUTER DO THE FOLLOWING !!
GOTO CONTROL PANEL
> ADD HARDWARE
>YES I ALREADY CONNECTED
>ADD A NEW HARDWARE(FOUND AT THE END)
>I MANUALLY SELECT FROM THE LIST
>NETWORK ADOPTER (CLICK NEXT)
>MICROSOFT
>MICROSOFT LOOPBACK ADOPTER
>GO TO NETWORK CONNECTION LOCATED IN CONTROL
>ASSIGN IP RANGE TO LOOPBACK ADOPTER
LIKE
IP 192.168.1.2
SUBNET 255.255.255.0
DEFAULT GATEWAY 192.168.1.1
DNS 192.168.1.1
ON THE SECOND COMPUTER PERFORM THESE STEPS
BUT WITH DIFFERENT IP LIKE SAME RANG 192.168.1.3
AND PING THE 1ST COMPUTER FROM THE SECOND
LIKE
ping 192.168.1.2 -t
TYPE THE FOLLOWING COMMAND IN RUN.
>IF YOU RECEIVE REPLY IT MEANS BOTH PC ARE CONNECTED TO EACH OTHER LOGICALLY.
>IF RECEIVE TIME OUT MEANS SOMETHING IS WRONG.
>PERFORM THIS STEP AGAIN FROM 1ST COMPUTER.
YOUR FILE SHARING AND GAMES START WORKING WITH NO INTERNET.
TO ACCESS FILES SHARING FROM PC2
\\192.168.1.3
REGARDS
MASSAM
WWW.BESTFASHIONSTYLE.NET
Posted on Apr 25, 2012
How to setup tp-link TL-MR3220 on xp2002?
Connect the router's WAN port to your cable-modem.
Connect the computer to one of the LAN ports.
No other "setup" is needed.
Apr 29, 2014 | D-Link AirPlus DI-524 Wireless Router
Does a Ethernet Switch(Unmanaged) have a default IP address?
There is a user guide on the tp-link web site. It looks as if this is just a layer-2 switch (ethernet) and there is no user configuration to enter. The IP addresses would come from another device on your LAN. A router or a server that supports layer-3 (IP) would issue addresses by running a DHCP server process on it.
Nov 02, 2013 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
I can not connect to ethernet through TL-SF1008D switch and now how to connect
This model is unmanaged, meaning it is plug an play. You need a router to assign IPs then connect this hub,
Dec 19, 2012 | Computers & Internet
How to configure my router
It's a switch (a smart hub), not a router. No configuration needed. Plug and play.
Nov 25, 2012 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
We have two computers and we can t connect at the same time
You must make sure your ISP- Internet Service Provider allows more then one conection.
Shut everything off for 2 minutes the start everything up 1 at a time giving time for full boot up of each in between each devicethis can often fix the problem but often you will need a router rather than a switch as a switch does not assign IP addresses so it will look as though both PC's have the same IP address and booting one or the other ofline.
If this is helpful please give it a Thumbs Up!!!
Good Luck!!!
Jun 13, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
I HAVE 30 TP LINK (TL-SF1008D) SWITCHES ATTACH WITH MY SERVER .IF ANY SWITCH WILL OFF OR DEAD HOW CAN I FIND THEM THAT WHICH SWITCH HAVE PROBLEM. IS THERE ANY SOFTWERE TO GET ALL SWICTHS MAC ADDRESSES OR...
A switch should not have bad ports, its just a basic level device not much higher than a hub. Make sure you are using straight through cables to connect pc's to it. you can tell if it is a straight through most of the time by looking at the colors from left to right. (see picture) this will not be the case 99% of the time but sometimes a switch or router will come with one for connecting to other switches (which is what crossovers are made to do.
nathan_f.gifNote the colors and check to see that both cables have the same. if one is different then it is a crossover (it crosses wires so that similar devices can connect together.) Hope this helps, good luck with your switch.
May 08, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
TP-LINK TL-SF1008D 8-Port Ethernet Switch Logo
5,465 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
