Question about Nokia 6120
Vevmy 6120 has frozen,can't do any thing with the key pad.whan i turn it on it only stays on for about 15 seconds
  • Nokia Master
  • 12,061 Answers
Hi well usually whenever I see phone in this condition in my shop, they are faulty, and often uneconomically repairable.
The very best thing you can do, is to take the phone to a Nokia service center, call a local or head office of Nokia and ask where one is, when there, please ask for a "Quote" as to the repair costs etc.
This way at least then you can make an informed decision as to repair or replace.
Now things to try first, Take out the battery, se if any better, NO, then try nd replace the battery with a new one, freshly charged. Try a Factory Reset, if possible. Get a manual,and have a look through the troubleshooting section...
Posted on Mar 28, 2011
Frozen mobile
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 31, 2012 | Sony Ericsson Xperia U Black Rubber Gel...
Screen has frozen, can't turn it off or move anything, just not working.
There are a few things you can try to resolve this:
  1. Hold down the power button for up to 15 seconds to reset the unit.
  2. If that doesn't work, you'll want to try changing the power connection to the unit. If you don't have it plugged in to the cradle or the usb cable, plug it in. If it is plugged in, try unplugging it.
In the event it stays frozen, eventually the battery will drain. When the screen goes blank, you can then plug the unit in and recharge it. Let it charge for at least 30 minutes and then try to power on the unit.
Mar 03, 2011 | Tomtom ONE GPS Receiver
Here is a nokia 6120 key pad problem what i can do in such a case
You can replace the face plate, new one will come with a new keypad.
Jan 16, 2011 | Nokia 6120 classic Cellular Phone
My gps frozen i turn and it stay pontin other
make sure it has a good charge on it, the look up on the top left corner and see if all the bars are green, if they are not, the satellites have not locked on.
with the unit on, press and hold the power button for 15 seconds,take it outside in clear view of the open sky, then power it back on by holding the power button for up to ten seconds or until it powers on and allow the satellites to link up.
if that fails, let me know by repling to this post
bill
Feb 03, 2010 | Magellan Maestro 4040 GPS Receiver
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Bmw 320d e46 2001 orange brake wornin light stay on replaced brake pads and installed new sensor in front back sensor looks ok
the way to reset the brake light is to turn the key to "on" without turning the car on. Let it sit there for 15-30 seconds and the light should go off by itself. If not, double check how you have the sensors hooked up.
Jul 19, 2009 | BMW 323 Cars & Trucks
Key stuck in ignition
Be sure its all the way in park or try neutral.Its possible that security system does not recognize the key. Is security light flashing or on steady? Shut all doors and windows,trunk,hood, turn off all accessory's,roll down drivers window, turn key off and remove for at least 1 minute, insert key into ignition, try to start leaving key to run position for 20 minutes, turn key to off,wait 15 seconds, try to start again leaving key to run, wait 20 minutes, turn key off,wait 15 seconds, try to start, again leaving key to run, wait 20 minutes, turn key off, wait 15 seconds, try to start. This should relearn key code. It may relearn after 1 learn cycle and start if system is ok. Hope this helps and that the weather is dry and warm for this procedure! This is not always a fix, but works most of the time.
Jan 25, 2009 | 2006 Chevrolet Monte Carlo
My iphone stays frozen on the apple screen
just try a hard reset by holding down the home and sleep buttons for 10 seconds. See if that works and then connect to the USB port of your computer and see if iTunes starts automatically and recognize it.
Dec 20, 2008 | Apple iPhone Smartphone
Help :0
That is what is happening to me except it is in mid game and not on the home screen. I have to pull the battery out also and start playing again. You would think buying Sony and for the price it would work better, so is Sony now making second grade handheld game console.
Aug 22, 2007 | Sony PlayStation Portable (PSP) Console
Nokia 6120 Logo
24 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
