Question about Google Talk
6E error flashing on my Samsung WF-B1061 washing Machine
HI, MY SAMSUNG WASHING MACHINE WF-B1061 RECENTLY GOT ERROR IT SAYS 6E WHAT DOES IT MEAN? AND ALSO WHEN I SWITCH ON THE WATER GOES IN PROPERLY BUT SUDDENLY IT TURNS TO ERROR. THANKS & REGARDS WILL
6e error mean heater not functioning. Check the heater element and if is bad change it. If the heater element is ok, check the connection to electronic board.
All the best !
Apr 21, 2018 | Samsung Washing Machines
Where we buy Samsung Washing Machine replacement part i need a (motor carbon brush) Model for WF-B1061
samsung authorized repair shop spares
go google to samsung spares direct
find an appliance repair shop as the motor may be generic or have generic brushes fitted
Sep 30, 2015 | Samsung Washing Machines
Wf 8800lsw samsung flashing spin light error code 5e
You need to clean out the debris filter behind the little flam on the bottom right hand on the front of the machine. If that gets clogged with anything, and you would be amazed at what ends up in there, you will get that message and the machine wont work.
Sep 01, 2014 | Samsung Washing Machines
Samsung WF-R1061 washing machine repeatedly trips
does it show an error code ? when it trips what is the washer doing filling water or spinning etc ? does it work on other settings like spin and drain with out tripping. ?
May 27, 2017 | Washing Machines
Samsung wf-b1061 give 4e errore
Here is the owner's manual:
http://www.manualslib.com/manual/147752/Samsung-Wf-B1061-User-Manual.html?page=10#manual
It says in troubleshooting section error 4E is a water supply issue. The screens on the watervalve may need cleaned. Remove supply hoses on back of machine to clean them. If no improvement check water pressure coming from supply hoses. If pressure is good watervalves may need replaced.
Jan 07, 2013 | Washing Machines
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
Hi, my samsung washing machine wf-b1061 has no power. however whenever i remove the plug from the outlet, i could see from the panel a blink. what could be the problem. is it possible that the mother...
i have a samsung washing machine, no power in my washing machine and i couldnt find in side any fuse, can you tell me what is the problem it? thanks
Oct 21, 2010 | Samsung Washing Machines
Willnot spin, error code 6e
lg wf-t851 will not spin. displays 6e error code
May 23, 2009 | LG WM-2277HW Front Load Washer
Operating of samsung WF-B1061 washing machine
You can download the manual direct from samsung just go to their site type in your machine and download.
May 22, 2009 | Samsung WF317AAG Front Load Washer / Dryer
I have a j1453 washing machine and im getting an error code 6e.what does this mean?
6E error means ambient temperature is too low.
A problem that occurs when the potentiometer connected in series with the thermistor on the microprocessor board is damaged.
for more details try this link:-
http://applianceguru.com/view_topic.php?id=3721&forum_id=2&jump_to=95478
As this is under generic problems on all washing machines, the link will surely help.
Dec 13, 2008 | Samsung Washing Machines
Google Talk Logo
233 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
