Question about Panasonic KX-T7130 Corded Phone
Kx-t7130 how do i program a programmable feature button or a co button to do dss, dial ext 105? ozzy.
  • Panasonic Master
  • 2,460 Answers
Depending on your system, you can switch the phone to program, press the CO button and dial 1 105 store. If it's a Feature button, jsut dial the extension (105) and store. IIRC the "2" is assumed on a feature button.
Carl
Posted on Aug 24, 2008
Can i set a dss button as a page feature? can i do this via pc prgramming by selecting one of the dss buttons on the 24 button phone, as a 1-touch dial, and then put in 330 as the 1-touch number?
You could, but it would be a whole lot easier to press PROGRAM the one-touch button on the right and dial 330 STORE.
Takes less time :-)
Carl
Jul 22, 2011 | Panasonic KX-TA824PK Phone
I wish to assign a flexible CO button to switch from day to night mode on a panasonic Kx-T7433 and can't find a resolution that works can anyone help?
There isn't a magic program to do that. The codes 781 782 on the intercom can be programmed under TWO buttons for DAY and NIGHT, or you possibly could program one button to dial 78 and you manually dial 1 or 2, but only the DSS console can be programmed for single button D/N switching.
Carl
Apr 28, 2011 | Panasonic KX-T7433B Corded Phone
How do i assign Extensions to the KX-T7433? Thanks
Pick a button that you want to use. Then from an idle phone, press PROGRAM 99 the button and dial 1 + ext no STORE. The 1 tells the system to make the button an extension DSS button.
Carl
Mar 29, 2011 | Panasonic KX-T7433B Corded Phone
I have the message CO Not assigned ,How can assig CO? panasonic kx-t7730
Press program button, select button you want to program, dial 0 then dial CO number as in 001 according to which CO line you wish to program. If you are not sure which CO line is missing, check the button programming by the same method. Press program button then any programmable button and it will be identified in the LCD screen. The CO lines may be 2 digit if you have an older system as in 01, 02, etc
Jan 26, 2011 | Panasonic KX-T7730 Corded Phone
I have a KX-T7456. Set 3 CO buttons for speed dial with new names and extensions. Busy light does not come on when those 3 lines are in use. Works on all the other numbers.
It's not speed dial, it's DSS. Names come from the directory (sys prog 004). The button programs from personal programming PROG 99? button 1+ext+STORE.
Carl
Jun 01, 2010 | Panasonic KX-T7456 Corded Phone
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
We have comdial impact 8324 phones here. One of our employees no longer has a DSS button that transfers calls directly to someone's voicemail. How can we program that back in?
Try this:
Storing a DSS Number -
Only one DSS number may be stored at each programmable button location but you may store a feature code or autodial number on the second level for a button location that already has the DSS programmed.
To Store an Intercom Extension Number as a DSS Number :
  1. Press optionS
  2. Press NEXT four times
  3. Press DSS
  4. Press the programmable button
  5. Dial the extension number
  6. Repeat as many times as desired
  7. Press SPEAKER to end.
NOTE: Do not program interactive buttons. If this occurs, you can retrieve functions by pressing INTERCOM "**1" , the interactive button and dial 91, 92 or 93 (from left to right). Attempting to program these buttons can cause features to be unavailable.
You can get more information from:
http://www.mainresource.com/PhoneTipsComdial.html#programming
Nov 04, 2009 | Computers & Internet
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
In the company to dial my colleague's ext. number(11)
Find a spare button on the left side of the phone and press PROGRAM, the button, and dial 1 plus her extension STORE.
Now the button becomes her DSS (Direct station select) and busy lamp,.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Panasonic KX-T7130 Corded Phone Logo
219 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
