After installing system from Recovery CD Windows not booting.
  • 26 Answers
Wats the error.
Try installing the system on a different drive.
Posted on Mar 28, 2011
  • 1 more comment
  • zilonitiz Mar 28, 2011
    No any errors. On screen Windows logo and system not responding. I hav try this solotionhttp://esupport.sony.com/US/perl/swu-dow... but it not help.
  • rajgeek Mar 28, 2011
    It would be better to format the drive and reinstall the os. If you have taken a back up before then you could get the data back using the back up.
  • zilonitiz Mar 29, 2011
    I have tryed remove partition, not help... Problem the same...
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
Feb 23, 2011 | Gateway 704GE PC Desktop
Tip
How to do System Restore when the computer doesn't even boot to Safe Mode in...
System Restore is assumed to be the best method to recover the system from Registry or System file errors. Its easy to perform and is effective, no doubt. But what happens when the system doesn't even boot to the desktop, neither in Normal mode, nor in Safe Mode. How do you do a System Restore then. For Vista and Win 7 users, its a piece of cake, since the WinRE provides them the direct option to System Restore from the installation/repair CD. But what for the XP users?
The following method is very useful and serves as a bliss for Windows XP users to recover their system from crashes due to Registry or System file failures. All you need for the method is a Windows XP installation CD. (This is not a re-installation process. All data and settings are intact after the operation.)
Step 1: Boot to the Recovery Console
  • Insert the Windows XP CD into the computer.
  • Turn the computer off.
  • Setup the computer to boot from cd: either by pressing F2, F9 or Delete to go in BIOS and changing the boot sequence or by pressing F12 on Dell computers to launch the Boot Device Menu.
  • As soon as you get the message 'Press any key to boot from the cd', hit enter.
  • Wait for the Windows Setup to initialize
  • At the Welcome to Setup screen press R to repair windows using recovery console.
  • You will be prompted to choose a Windows installation. Press 1 on the top of the keyboard and then press Enter.
  • You will be prompted to enter the Administrator password. Press Enter if no password was set.
Step 2: Accessing the Restore points.
Type the following commands in the Recovery Console.
cd system~1
If you get an Access Denied error:
  • Type the following commands to change the directory to c:windowssystem32config:
    cd windows
    cd system32
    cd config
  • Rename the system branch of the registry. That will allow us to access the system restore folder from inside the Recovery Console. In case the process fails and you want to perform a Windows Repair you will need to rename system.bak to system again.
    ren system system.bak
  • Type exit to leave the recovery console and to restart the computer.
  • Go back into the Recovery Console and repeat Step 2.
cd _resto~1
If the _resto~1 folder exists, inside it there are several folders named RP1, RP2. These are restore points. RP1 is the oldest restore point. You can use dir to view what RP folders are available. If there is no _resto~1 folder or if there are no restore points inside it:
  • Type the following commands:
    cd
    cd windows
    cd system32
    cd config
    copy c:\windows\repair\system system
  • If you are getting a file not found error try:
    copy c:\windows\repair\system.bak system
  • Then type the following :
  • copy c:\windows\repair\security security
  • copy c:\windows\repair\software software
  • copy c:\windows\repair\sam sam
  • copy c:\windows\repair\default default
  • exit
  • You will be able to boot into a altered version of the operating system. Backup your files from the c:Documents and Settings folder and then reinstall the operating system.
Step 3: Choose the most convenient RP folder.
Supposing we have RP3 available let's type in:
cd rp3
Change the directory to snapshot:
cd snapshot
Step 4: Restore the main registry branches.
If you are being asked if you want to overwrite type in y to agree.
copy _registry_machine_system c:\windows\system32\config\system
copy _registry_machine_software c:\windows\system32\config\software
The following commands are most of the time optional however the process might not work if they are not executed
copy _registry_machine_security c:\windows\system32\config\security
copy _registry_machine_sam c:\windows\system32\config\sam
copy _registry_user_.default c:\windows\system32\config\default
Type exit to reboot the system. Start the computer normally.
Thanks,
Abhishek
on Mar 22, 2010 | Microsoft Windows XP Professional
Tip
How to restore damaged system boot file.
When Windows system boot file is corrupted, the best thing to do is reinstalling the system.
This can be done either using original recovery CD, or using Windows setup disk.
To preserve your data you will need to chose partial recovery or upgrade setup.
Windows CDs has also a tool called Recovery Console that can be used to repair this kind of problems.
Here the procedure to fix the problem using Windows Recovery Console:
  • Insert Windows Setup CD, then start the computer.
  • When Welcome to Setup screen appears, press R.
  • When asked, chose the Windows installation you wish to repair (eg 1) , then press Enter.
  • When prompted, enter the administrator password .
  • When command prompt (DOS screen) starts, enter the following commands./ (if C: is not your Windows system drive, then change the drive letter)
    ATTRIB -H -R -S C:BOOT.INI
    DEL C:BOOT.INI
    BOOTCFG /REBUILD FIXBOOT
  • Remove the Windows CD from drive and restart computer.
on Sep 10, 2009 | Microsoft Windows XP Professional
Laptop
You PC is going to need a windows rebuild
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access bios the and change the boot order. Also some PC let you select the boot device by hitting f12 when the system is booting up, if this is the case make sure your window cd is in then boot from your cd or dvd drive
  2. Once you have made this change in your bios you will see press any key to install from your xp cd
  3. press ender to start the Windows Setup. Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console).
Mar 17, 2010 | Microsoft Computers & Internet
My friend has a toshiba satellite a120 and it has a error message saying nltdr is corrupt the system cannot boot any help?
If you have a windows CD, you can boot into the 'Recovery Console' - this is a command line type program on the CD that lets you perform Repairs on system files, and other things as well.
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
1. Watch for a Press any key to boot from CD... message similar to the one shown above.
2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Hopefully you have seen or will see a blue screen loading many files across the bottom. it will also offer you to press a function key for specific boot options. ignore all this until you get to the Setup Window
When the Windows XP Professional/Home Setup screen appears, press R to enter the Recovery Console.
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
The Recovery Console now needs to know the administrator password for this Windows XP installation.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
When you reach the command prompt, type the following two commands, pressing Enter after each one:
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
Sep 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Aspire 5100
Here you can find the solution to this problem.
http://support.microsoft.com/kb/307545
Jul 26, 2009 | Acer Aspire 5100 Notebook
Missing or corrupt hal.dll file, so can't boot the hard drive
Hey,
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Thanks and good luck.
Ekse
May 03, 2009 | Dell Dimension 3100 PC Desktop
Deleted dll
BOOT FROM YOUR WINDOWS DISC AND CHOSE OPTION RECOVERY CONSOLE AND USE THE GUIDED HELP...BUT FIRST DOWNLOAD THE MISSING FILE AND COPY IT TO WINDOWS 32 SYSTEM FILE FOLDER.RICHARDM69
Dec 01, 2008 | Dell Dimension 8100 PC Desktop
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
Enter the Administrator Password
The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
    Type Y in response to this question and press Enter.
  4. The next prompt asks you to Enter Load Identifier:.
    This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  5. The final prompt asks you to Enter OS Load options:.
    Type /Fastdetect here and press Enter.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
