Question about Samsung B3410 Cell Phone
Some incoming calls cannot be received it says call ended with no ring and i can not call back :-(
  • 118 Answers
Maybe you should try updating firmware, its probably a bug in their firmware. Just go to the support site of your handset and instructions will be provided on how to do so.
Posted on Mar 28, 2011
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Good luck from Headsets Direct!
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
Who know the call barring password for nokia E52 plz help !! :):) thnx
I am having a problem in incoming calls, there is red cross(inside red circle) appeared on my main screen of my mobile E52. The incoming calls appeared in received call but i cann't receive my incoming calls. If you have the solution please let me know
Apr 06, 2010 | Nokia E52 Smartphone
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
Sony Ericsson z750a incoming rings end too quickly.
cancell all call diverts. it may be happening due call diverting.
Jun 04, 2009 | Sony Ericsson K750i Cellular Phone
Cannot hear ringing tone or voices
Its the problem with the speaker... Change it...
Dec 26, 2008 | LG CU500 Cellular Phone
I have just puchased a new Fax machine, I only have one telephone line but when I sent the machine to Fax/Tel the machine takes over and keeps ringing until i press tele/Rev..I want to receive incoming...
I always setup my faxes with FAXONLY mode,I set the incomming ring to "on "and ring count to "7".
And check wat is your remote rx number-with that number you can dail it and it will go to fax automaticly.
Nov 04, 2008 | Brother Office Equipment & Supplies
Can't receive incoming calls
same here... I unlock it but it doesn't received call
Aug 16, 2008 | Motorola Mobility A1200
Samsung B3410 Cell Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
