Question about Universal Kreepy Krauly In-Ground Pool Cleaner
My Kreepy Krauly Bull Shark has never worked. I had it fitted by the Pool Company I bought it from. It keeps tipping on the one end and doesn't move, I pull it to the shallow end get it in the correct position and lo and behold over it goes again. The weight never stays where you put it and as the Kreepy Krauly moves it slides down the hose. I am so frustrated as my I have my previous Kreepy Krauly for 19 years and was told this was a better product, needless to say my nice sparkly clean pool is no longer clean although the water is still sparkly. I am desperate as I can no longer enjoy my pool, what a waste of time and money!!!!
    New Friend:
  • 44 Answers
Air in your line or a dirty filter will cause this problem
Posted on Apr 18, 2017
5 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Posted on Apr 14, 2010
Testimonial: "Great thank you for this info...I believe that I need to buy another type....too many problems with this type of cleaner."
jharwell668
  • 640 Answers
SOURCE: Hi, I bought my Bull
If it has never worked properly, it could be that your pump and filter system are too small for this particular automatic pool cleaner. If you don't feel that this is the case, there a few things that you can check. Make sure that there is not debris in the flapper. It could be causing a loss of suction, making the pool cleaner rise off the floor of the pool. Also, check your water flow coming from your return line. It could be too high. You can adjust it with an eyeball diverter if necessary.
Posted on Feb 01, 2011
jharwell668
  • 640 Answers
SOURCE: Hi, I also bought my
First, check for debris in the pool cleaners flapper. This can cause a lack of suction the floor. Also, check for proper hose balance. If the hose rests at a greater than 45 degree angle, the hose is too light and you need to move the hose weights closer to the cleaner. If the hose rests at a less than 45 degree angle, you need to move the weights away from the cleaner.
Posted on Mar 08, 2011
jharwell668
  • 640 Answers
SOURCE: Kreepy bull shark gets stuck
There are several things that you can do to prevent these pool cleaners from sticking at steps and corners. First, your return line water flow might be positioned incorrectly to force the cleaner toward the corners. Check for this and use the eyeball diverter valve to redirect the water flow if necessary. Make sure that your automatic regulator valve is installed properly and free of debris. Make sure that you have proper hose balance (the cleaner should set at a 45 degree angle to the pool bottom). Adjust the hose weights if necessary. You may need to add a wall climb restrictor or a ladder guard. If none of these correct the problem, consider adding the Thruster, which aids in random pattern coverage by automatically repositioning the hose to help free the cleaner from obstacles.
Posted on Apr 20, 2011
Kreepy krauly Bull Shark
Had the unit been running okay before? It sounds like a water flow issue. (not enough water being pulled through the head) Check for leaks in the hose, verify pump is fully functioning and filter pressure is not high.
Nov 11, 2013 | Pool & Spa
Hose broken where it fit into the kreepy krawley
Go to an autoparts store and ask about EASYOUTS. They are reverse tapered tools that fit in the opening and grab the piece and screw it out.
Oct 14, 2012 | Universal Kreepy Krauly In-Ground Pool...
BROKEN SUCTION HOSE CONNECTOR DOWN IN SUCTION WELL
Contact them direct. This is not something that can be answered by Fixya, especially as this is an Australian product and we are a North American self help website.
Pool Cleaners ' Automatic Pool Cleaner - Kreepy Krauly Pool Cleaners
https://www.kreepykrauly.com.au/Kreepy Krauly is Australia's most trusted and innovative automatic pool cleaner. Request a free pool cleaning demonstration with one of our pool cleaners today.
Kreepy Krauly Google Search
Aug 25, 2017 | Universal Kreepy Krauly In-Ground Pool...
I have a 20X40 rectangular liner pool and my kreepy krauly stays in the deep end of the pool. I think I need to adjust the weights. Where should the weights be placed?
The first weight from the cleaning head should be adjusted so the Kreepy sits flat on the floor with the system turned off. Then you can start moving the next weight until it starts climbing the hill to the shallow end. It may take a few times but if you get the weights set correctly it should work.
Aug 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, I also bought my Bull Shark Kreepy Krauly recently - 3 months ago. Since day 1 it liftes up at the end and does not move flat on the surface of the swimming pool. Please assist.
Feb 11, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, I bought my Bull Shark Kreepy Krauly recently and from the start it lifted up at the end and does not move flat on the surface of the swimming pool. Please assist.
Jan 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
Recently bought a bull shark creepy from Mica Benoni, and although it does clean the pool ( when it is is facing down), it climbs the walls ( sometimes and falls over onto its back and stays there the...
I have the same problem as well. There is nothing obstructing the the kreepy from sucking. This seems to be a general problem with the bull shark. I have gone to the pool places and without me telling them about my problem with the kreepy they told me what the problem is with the bull shark. My friend has the same problem with his. Mabe there is someone that work for kreepy crawly that knows how to solve this problem.
Jan 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Jan 03, 2010 | Pentair Kreepy Krauly Inground Automatic...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
908 people viewed this question
Top Universal Pool & Spa Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
