Question about Ovens
Oven not working...despite changing elements - Ovens
  • 2,510 Answers
Check the control switch and the selector that they are working, If there is no problem there then look at the oven, it has a thermal trip switch behind the back wall of the oven, it is accessed from under the back cover. It is a small plate like part with two terminals attached to it and it may have tripped out. It is attached to the back outside wall of the oven towards the top. Some thermal switches can be reset but most usually have to be changed. They come in different heat ranges, so be sure to match the new switch to the old one. You also need to find out why the switch tripped in the first place - it could be a faulty thermostat etc.
If you are handy you may be able to open the switch and click the little disc out again and reassemble the switch. Make sure to refit the disc the right way around. Ensure that the power to the oven is off or the plug is pulled out before attempting to remove the back cover.
Posted on Mar 28, 2011
    Problem Solver:
  • 11 Answers
Go check your fuse box! The fuses should b labeled as to which one is which.when u find the one for your oven/range...flip both switches to it off then flip both back on. See if that works
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
GLEB30T8CSA upper oven baking element has no power
It may be you have a bad element. If you remove it and have a volt meter you could check a the socket for power. Also if the upper and lower elements are the same change the working one to the upper oven and see if it works. If it does you need to purchase a new element. If there is no power to the upper oven you may have a bad control ora broken wire behind the panel. I would advise you to turn off the power to the oven before pulling or changing any componets.
Mar 02, 2013 | Frigidaire GLEB30T8A Electric Double Oven
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
I have an AEG B6139 electric oven and the interior light and fan comes on but the oven will not heat up despite putting the setting on high. Next to the dial for the interior light and fan a small red...
Hi I am Vortash it sounds to me as if the oven element has blown you need to have it tested by an engineer .. he will check for continuity .. if it is open circuit then you will need to replace it .
I would hev thought that if the fuse had gone the oven would have no light or functions of any kind as the power would be off .. unless this model has an extra fuse fopr the element alone doubtful however it does have a heat sensor cut off above the oven that cuts off the element from the supply .. If you have no manual for this unit you will find one free to download from http://www.safemanuals.com .. regards Vortash
Apr 29, 2009 | AEG B3101-4 Electric Single Oven
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
65 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
