Question about HP Pavilion dv6000z Notebook
Hi my hp battery is not charging and is making a beeping noise what can i do to fix it?
  • HP Master
  • 32,281 Answers
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Mar 28, 2011
I am broken down and vehicle swings over but will not start. Engine light is on. battery is good. Beeping noise while swinging
Tthat beeping noise is telling u whats wrong dont let the battery die it will clear the code and u wont find ur problem so charge it every week i need to know the beeping on it
Jan 06, 2015 | 2006 SsangYong Rexton RX
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
Smart charge light is blinking and beeps after evry 10 min
Check to make sure the batteries havn't failed.
you will need a Multimeter to verify this... preferrably underload...
Feb 05, 2013 | Computers & Internet
My scooter battery won't stop beeping
hi, that's sounds like the freewheel lever is engaged, please make sure it out of freewheel mode, now remove the rear axle then refit, does it still make that noise ?
Yes, okay now check the connection from the rear axle to the frame, make sure they are clean and a good connection,
Regards
www.gewizrepairs.co.uk
Dec 27, 2012 | Sunrise Medical Guardian Trek 4
Mobility scooter beeping noise
what kind and model. also is the battery charged up? no battery no using.
Sep 11, 2012 | Health & Beauty
I cant charge mine. it keeps making a beep
Two possibilities come to mind. 1) The battery has failed and can't be charged fully (usually one cell fails and it won't charge fully). I've diagnosed this by removing the battery and trying to charge it with a variable power supply. You can try replacing the battery.
2) The UPS itself is faulty and can't charge/maintain the battery. The entire unit should be replaced.
I recommend solution 2. I had the 725VA in this consumer UPS line and when I replaced the battery, the UPS could not keep the battery charged with any load on the unit.
Check your warranty, though. The APC warranty is for 2 years on this model.
I hope this helps.
Jun 02, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
My pc doesn't reboot!
You've not given much to work with!
Is the AC adapter working?
Is the battery inserted? Is it fully-charged?
When you press the ON/OFF button, does your computer make ANY noise at all? Fans spinning? CD-ROM spinning? Disk-drive "clicking" as it "calibrates" itself? Do you hear one "beep" or multiple "beeps"?
Take the computer to a qualified technician for trouble-shooting.
Jan 04, 2010 | HP Pavilion dv6000z Notebook
Hp530 turn off suddenly
Get a power charging adaptor from HP (if a smart adaptor) or a generic anywhere that matches your spec. Your device is doing what mine did, but in addition mine beeped softly as a warning of failure. Being a smart adaptor, I had to order one from HP, a generic won't work.
Sep 05, 2009 | HP 530 Notebook
The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Mar 15, 2009 | Toshiba Portege R100 Notebook
Charging
It's beeping because the battery is completely dead and needs to charge. If beeping doesn't stop after a while of charging, you may need a new battery or a new charger.
Jul 21, 2008 | Motorola Mobility RAZR V3
HP Pavilion dv6000z Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
