Question about LG WM-2277HW Front Load Washer
My LG washing machine model Tromm front loader not working properly.If we set time for 1hour 30 minutes it is not running after 43rd minutes or SO.If timer problem,what to do.Advise please
    Master:
  • 354 Answers
Usually there is a timer relay that is in there that needs to be replaced ,check that out its a big cube looking thing with four or five prongs on the bottom for contactors
Posted on Mar 28, 2011
How do I open to remove the water on an LG tromm front load washing machine to repair/replace the pump?
LG machines normally have a small diameter rubber pipe folded up in the drain pump basket area on the lower left side of the front panel.
Pull out the pipe and remove the small plastic end stopper to allow the water in the tub to drain.
Sep 20, 2014 | LG Washing Machines
Have a lg tromm front loader and am wondering if it is ok to run regular detergent instead of the hd stuff. C.
Not recommended. When buying the correct product you should also find the front loader much more economical on washing powder than a top loader.
Mar 05, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
Getting the OE error message on LG Tromm
Wash cycle taking way too long, like 90+ minutes
You timer is bad and needs to be replaced. Your problem is a common error and is something a lot of people on here run into. You can go to repairclinic.com and get this looked at
May 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG TROMM washer.It is not washing properly.
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm front loader-FE error code
The water overfills due to a faulty water valve. The valve needs to be replaced.
Sep 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm washing machine WM1812CW keeps coming up with error 0E. how can I fix it.
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Jun 01, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
93 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
