Question about Fusion FEW12PK Car Subwoofer
Hi, I have a "Fusion
  • Randy Simmons
    Randy Simmons Mar 28, 2011
    Hi Mark,I'm Randy. B4 i advise you on the solution to your problem,i need foryou to check something and get back to me.....I want you to connect a 12 volt test light between the live power lead and the switch connector and let me know if your test light light's up.
  • 4 Answers
SOURCE: AMPLIFIER PROBS
there are only three wires that control whether the amp powers on or not. battery, ground and remote. if any one of those are not hooked up correctly and securely then the amp will not turn on. the ground point needs to be clean to be good. and u might want to make sure none of the wires have a break in them
Posted on Jun 04, 2009
ricomun
  • 24 Answers
SOURCE: hi i have fusion sub woofer can u help me to
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Posted on Jul 06, 2009
SOURCE: ive wired my fusion amp and sub but no sound
The orange wire, where do I conect it?
Posted on Aug 13, 2009
etirbynnor
  • 655 Answers
SOURCE: i have a fusion sub and amp and have no
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Posted on Sep 11, 2009
SOURCE: sub making noise without input
Hi there guys, i dont have this problem ,but i do have the EN-AT1100 encounter 10" and cant get the thing to work at all. The six pin plug for the power (12V+), earth (GND) and accesories (REM) are all muddled up as i never bough it with the original leads. Can any of you help me out with the wiring on how to connect it? is there two wires for (12V+), two wires for earth (GND) and just one wire for accessories (REM)?
Hope you can help thanks.
Posted on Feb 27, 2010
2004 fusion 2 oil warning light fuse where is it if there is one??
James I have in the recent past drove my car up to advance autos and they will plug in a computer for your car free of charge so you will positively know what is wrong. It may be the sending unit that screws into your engine block. I'll give you a link so you may locate one nearby: Advance Auto Parts Car Engine Batteries Brakes Replacement Performance... Thank you and best of luck. Please leave feedback.
Jul 13, 2016 | 2004 Ford Fusion
When do I change the timing belt on 2004 Ford Fusion?
you will be able to see cracks in the belt usaully they last a few years at least
Jun 06, 2012 | 2004 Ford Fusion
Hi, My air conditioner is working, but the warter is leaking inside. It is 3 years old. Any ideas? Thanks.
There is a drain pan under the evaporator coil that has a tube connected to it to drain the water to the rear of the unit where it exits the unit. I suspect that the pan and/or drain tube is filled with gunk. You have to take the front cover and then the metal enclosure off the unit to clean these out.
Aug 08, 2011 | Frigidaire Heating & Cooling
Hi...I have a Onkyo CS-V720S ...I would like add at these sistem ACTIVE SUBWOOFER, CENTER AND SURROUND SPEAKERS...what model of speakers do you recommend?...........thanks
Whatever additional speakers you decide on they all have to be self-amplified.
If you want opinions you could search the web for some actual user reviews. I don't know how many of the 'experts' have any experience with that end of the line. I read a few but never found anyone who actually decided to expand on the basic unit's stereo-only capabilities.
Maybe check out Amazon for what "Customers Who Bought This Item Also Bought".
Jul 11, 2011 | Onkyo CS-V720 Shelf System
I have a Mitusbishi CS-40503 tv that is approximately 17 years old. When I turn it on, the entire picture is blurry (like your glasses are off) and then after about 7 minutes, the picture is crisp and...
Hi sletwin,
This symptom indicated of faulty CRT socket (picture tube socket). A few days or weeks time the symptom will remain and will not back to clear picture. Below is the sample picture of the socket where is connected to the picture tube.
You may replace it yourself if you have a little knowledge in soldering and disoldering technique. There are two wire soldered in this socket from the flyback, one is the screen and the other is the focus.
Try to buy from your local electronics supply, bring the actual sample because many types are available at the market.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 13, 2011 | Mitsubishi CS-40503 TV
I have a new GlowFusion Tanning System. It was spraying and now nothing is coming out. I can see bubbles being made in the solution and when I take it out I can feel air blowing through the nozzle
Hi it seems that the product is not there in that bottle its just the air with less product, if you have recently bought it then go back to the store complain it and return it,
Apr 14, 2011 | Fusion Beauty GlowFusion Intuitive Active...
"Go to any computer-store. Purchase an "empty"
You did not explained your problem very well. How can we help you. Please elaborate.
Feb 06, 2011 | HP Computers & Internet
Need an enclosure for a WD1600, model # WD1600JD-40HBCO
There are many places to get enclosures for hard drives. I would recommend looking for a USB 3.0 (the new standard for hi-speed USB, and backward compatible) interface, and for an enclosure that includes an active cooling fan.
Otherwise, it's take your pick.
Hope that's helpful.
Jan 01, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
I have a 2006 Ford Fusion, 4 cylinder. Rough
please say you did not get the engine steam cleaned...as you can cost yourself a LOT of money.hopefully the heat will dry things out, otherwise get the car put on a diagnostics machine.
Jun 20, 2010 | 2006 Ford Fusion
How to active my adobe photoshp cs? my activation number 4257-5036-3092-3981-2277-4200-2217
Good afternoon. There are several ways to activate, including calling Adobe, but using the internet takes just a few seconds. If you are in Photoshop go to help registration. This will walk you through the steps.
Feb 22, 2009 | Adobe Photoshop CS for PC
Fusion FEW12PK Car Subwoofer Logo
152 people viewed this question
Top Fusion Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
