Question about Microwave Ovens
I am looking to purchase a pilot light ( Knob Only ) if possible as the back of the knob is broken and no longer stays on the pilot light shaft, otherwise it all works fine. Number on back of beige knob is 82220 Model: 35C +S Can you please advise where I can purchase one in W.A Thank you
    Master:
  • 354 Answers
Appliance store ,there is one in every town of any size or you can find it on line
Posted on Mar 28, 2011
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
How to use oven in gas cooking range
turn the knob to 350 and wait til it heats up or try lighting the pilot light underneath the bottom oven rack
Sep 15, 2013 | Microwave Ovens
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
How do I tighten the Timer Knob on my Whirlpool AVM 950 Microwave Cooker Hood Combo?
Look to see if a flat nut under the knob or a Allen nut/bolt that secures the knob is loose--some are drilled into the side of the knob.
Jun 14, 2012 | Microwave Ovens
We need a new bottom timer knob. Where can I get one? Thanks!
The cheap answer is at your local appliance recycler. You can also get knobs from electronics suppliers such as MCM Electronics, Mouser, or Digi-Key. MCM carries original appliance parts, so you may be able to find the part by sending an e-mail to their sales department with the brand and model number of the oven.
Otherwise, you will need to specify the shaft type (probably 1/4" D) and outer knob diameter.
I have successfully repaired cracked D-shaft knobs with JB Weld metal-filled epoxy. The hard part is clamping the pieces so you get a good fit when the epoxy is set..
Jan 16, 2011 | Microwave Ovens
I have purchased a Brovetti model T0283 B 6 slice convection toaster oven. I love using this, but the knob for the timer has broken off. Could you possibly replace this item for me???
You should be able to find Bravetti spares here.
Aug 26, 2008 | Microwave Ovens
MR 522W Welbilt microwave oven
While, the original part number was MW-4000-08, to my knowledge, parts are generally no longer available for Welbilt microwaves. The good news is that this knob should be for a standard 1/4" shaft with a flat side, and appliance parts stores, home centers, and home improvement stores will have a good selection of knobs. If you take your old one, you should be able to get help matching it so it will function for you. Good luck.
May 14, 2007 | Welbilt MR95TW Microwave Oven
While the original part number was MW-4000-08, to my knowledge, parts are generally no longer available for Welbilt microwaves. The good news is that this knob should be for a standard 1/4" shaft with a flat side, and appliance parts stores, home centers, and home improvement stores will have a good selection of knobs. If you take your old one, you should be able to get help matching it so it will function for you. Good luck.
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
