Question about Bosch Washing Machines
Bosch Classixx 1400 Express: stopped midway through wash cycle, making a high-pitched beeping noise. Water and clothes are trapped in the machine. I have tried setting it to drain and spin - just makes a horrible grinding noise and doesn't empty. I need the clothes that are in there! Please can you tell me what to do?
If there is still water in drum the door wont open try tilting the machine back so the water is not touching the door and wait for a click that normly works
Posted on Mar 28, 2011
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
check your detergent. You should only be using detergent that has the "he" symbol on the front of the bottle. It stands for high efficiency. Its made for washers that use less water so that it rinses completely. If you use regular detergent, suds will be left after the cycle is finished.
Nov 27, 2013 | Washing Machines
My bosch classixx 1400 express washing machine drain pump sometimes does'ent work
bosch classixx 1400 express washing machine drain pump This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 13, 2013 | Bosch Washing Machines
Bosch Classixx 1400 Express does not start at all, does not fill.
fit new door interlock switch ..Take note of wiring 1st//
Oct 04, 2009 | Washing Machines
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
420 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
