Question about AGA Refrigerators
Hi my aga refrigerator has warmed up to 12 degrees i have hoovered all the top vents i do not know how to reset it to a cooler temperature please help
  • AGA Master
  • 20,902 Answers
Remove the wall plug for 10 minutes and then plug it back in. If the temperature doesn't start coming down, you need a service call. Most likely cause is the refrigerant gas needs topping up. It can also be that the evaporator is frozen up. That is the radiator type item that chills the air moving through it. It is best to have an engineer fix that as their is always a reason for freezing up.
You need to vacuum the compressor coil fins rather than 'the vents'. The compressor fan draws air through it to cool the refrigerant gas and the compressor itself. You would normally have to remove a vent to get to it. sometimes they are on the rear, sometimes on the top, sometimes underneath.
Go to Bing homepage
Posted on Jul 09, 2016
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: My Samsung refrigerator freezer model RB1955SW is
You have a very simple problem. Replace the door switch. That should take care of your problem. The reason for the bell is because one of the switches is bad, top or bottom either way it's only one switch and is detecting that one of the doors is open. It's not cooling well because the light is always on. I hope this will solve your problem
Posted on Apr 29, 2010
SOURCE: My Samsung Refrigerator can not keep the set temperature.
DO NOT BUY ANOTHER SAMSUNG PRODUCT _ BOYCOTT
Posted on Jul 08, 2010
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
We lost power and my fridge will not stay cold
Hi! May I ask If you feel the motor of the fridge humming or something? Is the light inside working or it is completely dead? Hope you can tell me more. Thanks!
Jul 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Drawer temperature is ten degrees cooler than main part
This is affected by whether the fridge is bottom freezer or top freezer.
The drawer temperature is controlled by air drawn from the freezer. There is usually a vent control to adjust the amount of cold air that gets pumped into the drawer.
Do not allow food or bags to block the vents where the cold air is injected into the main compartment.
Open the drying vents more on the drawers if there are any.
Mar 20, 2010 | LG Refrigerators
Same problem,cool freezer ,hot refrigerator
Try reducing freezer temperature. Unplug and let main control board reset. I need to assume you have the PSS26MGPABB model when I ask you to do this. I can send you the manual and assist you if you want. Let me know, Thanks Sea Breeze
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
How to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Refrigerators Logo
47 people viewed this question
Top AGA Refrigerators Experts
John Tripp
John Tripp
Andrew Taylor
Andrew Taylor
Stan Ford
Are you an AGA Refrigerator Expert? Answer questions, earn points and help others
