Question about Intel DG31PR Motherboard
Intel DG31PR Motherboard Problem
I have an Intel DG31PR Motherboard with Intel C2D Processor and 2 GB 667 Mhz. DDR2 ZION RAM. When I am trying to install windows 2003 ser ver it returns with Memory Dump Error. Plz. help.
  • 84 Answers
Memory is key element on all motherboards and hard to believe they are all selective of memory . You have the wrong memory for that motherboard . Sorry . Here is list you can select for the motherboard ( only ones that will work with it )
http://www.intel.com/technology/memory/ddr/valid/DDR2_667_dimm_results.htm
Anything other than what is listed will not work with your motherboard .
Posted on Aug 04, 2008
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the...
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Jan 02, 2011 | ASUS P5RD2-VM Motherboard
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
Poor performance
First of all "DAMN" can I have your PC lol jk, you upgraded to high for XP you have a Visa compatible upgrade. That motherboard doesn't support XP servise pack II. sorry if you dont like Vista but this OEM is the only thing that will work properly now.
Jun 20, 2009 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
125 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
