Question about Garden
After having the motor going on my Talon Line Trimmer and, the line head not moving, I have removed the lower section of the pole. I can not see how to gert into the pole to find out why the drive cord is not connecting with the head. How do i get inside the fitting on the pole to see if the keyway on the head needs cleaning or if the keyway is shot.
    President:
  • 3,074 Answers
The flexible cable that moves the head is connected to the motor and runs through the pipe to the head, it is either out, or stripped. You will need to remove motor and head, look inside as it is shaped like a socket, the part that hooks to the ratchet. If all is good and the cable is good then reinsert motor and head back into the slots. Hope this helped Tim
Posted on Mar 28, 2011
Talon electric line trimmer AT202A12 motor bearing noisy
https://www.youtube.com/watch?v=mXVYXWndPiA
Jan 22, 2016 | Garden
What id availability of replacement parts for a Colt line grass trimmer
Hi, Best go to the dealer and they can get you a replacement part or new trimmer head. Good luck.
Jan 07, 2016 | Garden
Fuel hoses and filter need replacing and a spark plug for a Talon AT3351A line trimmer
The manual has some instructions for doing these tasks on the Talon At3351a Line Trimmer. Here is the link for the Talon At3351a Line Trimmer manual.
Jan 21, 2013 | Garden
Stihl hl75 pole trimmer. Blades don't move. Cable turns when cutting end is off machine, but will not drive blades when it is attached. Anyone have an idea as to what's going on?
More than likely a gearbox problem in the cutter head. They can break teeth on the gears and also have delicate needle bearings than can wear if they are ungreased. Maintenance is paramount on these moving parts.
Jul 26, 2012 | Stihl Hl75 Line Trimmer Owners Manual
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
How to replace accessories from a husqvarna power motor
Straight from Husky, the pole saw runs about $200...or if you have the straight shaft, you can get just the head for $185:
http://www.husqvarna.com/us/homeowner/products/trimmers/popular-accessories/
May 05, 2010 | Husqvarna 28cc Gas Line Trimmer
I have a Talon electric line trimmer AT2309A and cant even seem to move the starting button to get it to work. Please help.
You need to move back the safety button on top of handle first. The safety button can be a bit stiff to move.
Nov 07, 2009 | 2006 Eagle Talon
I have replaced the line spool with a new one and it will not run
hey mate, the best thing to do would be try eliminate sections if the head does not spin remove it see if the arbor that the head connects spins with the head removed, if it still does not spin remove remove your drive shaft and check if motor actually spins some of these contain sheer pins to prevent damage to the motor, I would highly reccomend this be done by a professional as there is moving parts and electric motor involved... hope this helps
Brad:)
Sep 20, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
