Question about Epson TM-U220 Matrix Printer
I am having a dos program to print on the TM-U220 which is having only USB port. The network RS232 port is there but cable is not available.
  • 10 Answers
SOURCE: My Printer EPSON TM-U220 does not print....HELP!!!!!
if you are using lpt1 we expect that your printer is using a parallel cable. make sure that your printer is indeed using parallel cable and then check if there's a communication in between the 2 devices. to find out open your command promt then type in, dir>lpt1, your printer should print with or without a printer driver. if it will print, then possible issue is port configuration.. just make sure from the printer properties that you are using lpt. you can use esdprt lpt1 with bi-dir or lpt printer port without bi-dir support. you should be good to go from there. otherwise you may uninstall and reiinstall your printer driver..
Hope you can now use your printer..=)
Posted on Feb 23, 2008
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
Basti
  • 1447 Answers
SOURCE: epson tm u220
What type of interface card are you using to connect printer to your computer?
Posted on Apr 04, 2008
  • 7 Answers
SOURCE: TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
Posted on Aug 13, 2008
SOURCE: Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
Posted on Sep 10, 2008
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Tm u220 java
Are you printing from inside a java program (output) or from a java program editor.
Use the command to Open an output file, have all your output sent to the output file, close the output file properly before you exit the java program. After you finish send the output file to the matrix printer as you would with ASCII file. If the printer is installed properly, your OS should know where to send the output.
Dec 23, 2013 | Epson TM-U220 Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
TM-U220 sometimes fails to print
Maybe the USB cable or the port on the PC or PRINTER is defective. First try a different cable, then try another open USB port to see if it works there. Also, the POWER CORD for the printer may be loose or defective, or maybe one of the printer DOOR INTERLOCKS may be intermittent, or not closed properly.
Nov 25, 2008 | Epson TM-U220 Matrix Printer
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Epson tm u220
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Jan 14, 2008 | Epson TM-U220 Matrix Printer
hi basiime
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
131 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
