Question about Peavey ValveKing 100w All Tube 212 Combo Guitar Amplifier
Increasing staticky noise when turning up the gain knob on overdrive channel
  • Peavey Master
  • 5,603 Answers
If it is just while turning the control, open the unit and squirt some CRC226 into the control through the slot where the leads go in. You can bend the plastic spout to get it to spray into the slot. While your at it, do the other controls as well. CRC 226 is available at Home Depot in the electrical dept. Blue can about $2.70. Use only the 226 product as there are others there.
Posted on Mar 28, 2011
Clipping always lit
  1. Make sure nothing is plugged in.
  2. Turn the GAIN, LEVEL, and FX knobs for each channel, counter-clockwise all the way.
  3. Bring the MAIN fader all the way down.
If the signal LED's above the MAIN fader are still lit, then the board most likely has a short in it and will require repair.
If the signal LED's are dark, repeat the following on each channel...
  1. Rotate GAIN clockwise until the mark on the knob is at "12 oclock".
  2. Rotate LEVEL clockwise until the mark on the knob is at "3 oclock"
  3. Raise the MAIN fader to "0".
  4. Check LED's - if they light up then the channel you are working on is "noisy" or has a short in it.
  5. Return GAIN, LEVEL, and MAIN to "all off".
  6. Repeat with next channel.
Jan 25, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Extreme differences on overdrive channel
Please, take it to a tech in your area, or look for a good one to ship it to. An 2007 amp is not old at all.
Jul 24, 2017 | Marshall Mg100dfx 100-Watt Combo Guitar...
I'm trying to plug an active speaker into aux 3 for a third monitor mix but it doesn't work (I do the same with aux 1 and 2). Am I missing something? Cheers,
I answered another post of this earlier. The AUX3 is strictly POST FADER... you MUST turn the channel sliding fader up to send signal to AUX 3. Also the AUX3 channel gain KNOB must be turned up. Also the AUX master gain KNOB must be turned up. Make sure your cablles are balanced TRS cables from the mixer to the powered speakers.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
I am having problems with the effects. I cannot get any effect from it now. Please, help!
Make sure that BOTH the FX gain at each channel you want the FX on AND the "FX to Main" gain are turned up. Also when you select an effect push in the selection knob to activate the selection.
Jan 21, 2011 | Behringer Rx 1202fx 12 Channel Line and...
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Fender Deluxe. The volume knob has no effect whatsoever. Volume only changes with the drive knob.
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here:
http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Have fun - it's a great amp.
Oct 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Mackie CR1604 has a consistent click at hi gain
Without hearing the noise or seeing it on a scope, I can't say for sure, but this type of noise can come from a number of sources. If there is a high signal level on one bus, you could be getting some cross-talk from that channel onto the channel with the higher gain setting. Try to track this down a bit by experimentation. For example, do you hear this with NO connections at all, but with the gain turned up on one channel?
Please try a few things to narrow this down a bit and I'll try to provide you with some options.
Thanks,
Dan
Jul 20, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Peavey ValveKing 100w All Tube 212 Combo Guitar Amplifier Logo
89 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
