Question about D-Link DIR-300 Wireless Router
Can not get wireless access, have a blue cable that we can not find where to plug in...
    New Friend:
  • 68 Answers
From your modem, connect it to your router with the port labeled internet in its top. connect your pc or laptop to others ports. Not in the port with label internet , its for the modem or internet conncetion provider.
Posted on Mar 28, 2011
Blue wireless not flashing
Seems the cable is not working. Try to find another cable.
May 24, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can...
the blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
Apr 17, 2011 | D-Link DIR-615 Wireless Router
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
How do you hook up the wireless router
First configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Then save settings and restart router. Then connect internet cable from service provider to your router's WAN port.If you want wired internet then connect lan cable from computer to router's lan port. Let me know if you need further assistance. Thanks for using FixYa.
Oct 16, 2010 | Computers & Internet
Installation problem: D-link wireless router WBR-1310
  1. Push the RESET button on the back.
  2. Plug in the computer only into one of the 4 blue ports (and the router power plug of course).
  3. Give it a minute or two.
  4. Open a browser on your PC, type 192.168.0.1 in the address bar. No www or anything should be there.
  5. You should be able to access the router menu from this address. If this doesn't work, the default address might be listed on the bottom, along with the username and password
  6. If the above steps are successful you should be able to access the internet when you plug in your cable/DSL modem into the WAN port.
From another PC the manual can be downloaded from here:
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip
Hope this helps.
Jul 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I'm trying to access my wireless Linksys router to secure it.
First inplug power from router via the jack(not the wall outlet) and then unplug the cable going to the modem, take the blue ethernet cable that comes with router and plug into internet port now you can secure your router without worrying about internet threats. Open your web browser , in the url bar type 192.168.1.1 hit enter and a window should open, asking for username/password if you have not set one the default is admin in the username field then hit enter. If you have already password connected it and forgot password you need to unplug everything from router and then hold down reset button on back. There will be a screen that will walk you through all aspects of setup, security, firewall, wirless setup , wireless security, and it will give you a break down of all options on the right side of each window. Important to setup a passkey!!! Otherwise people can get into your network easy. once setup plug blue cable into ethernet port and modem cable into internet port. plug in power and you should be set. The cd that came with router should be first used. Do not broadcast wireless ssid and use wireless pin to connect computer.
Jan 31, 2010 | Linksys Wireless-G Broadband Router
Windows vista which USB cable do I need to use a
As far as I am aware the mouse you are talking about is NOT blue-tooth but a regular wireless mouse.
It came with a small wireless dongle that plugs into ANY regular usb port and does not need a cable.
Blue tooth does not usually use cables either as it is a wireless format but different to regular wireless
If your mouse is blue-tooth then you should ensure that your laptop or pc also has blue-tooth.
Should it not have blue-tooth then to use the mouse you would need to purchase a usb blue-tooth adapter. this is not a cable but is classified as a "dongle" you that's true !
This dongle plugs into any regular blue-tooth port on occasion windows will detect and install the required files but some blue-tooth dongles will come with a cd that you need to install.
If this information was useful please click
Aug 16, 2009 | Trust (14694) Keypad, Mouse
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Belkin F5D5231-4 - create a wireless access point
I have had good luck with the NetGear Rangemax WPN824. It has multiple antennas that are supposed to provide better range, and your kids will like the blue blinking lights.
http://www.netgear.com/Products/RoutersandGateways/RangeMaxWirelessRoutersandGateways.aspx
Nintendo has a list of incompatible wireless routers:
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterIncompatible.jsp
and the Rangemax is not incompatible.
Wii can use 802.11B or G.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterChoose.jsp
Since the Rangemax is both a wireless access point and a router (with 4 ethernet ports), you can just replace your existing router rather than plugging this router into your other one.
Jan 05, 2008 | Belkin (F5D5231-4) Router
D-Link DIR-300 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
