Question about ASUS (wl500g) Wireless Router
I don't know web user and password for asus routers
    Problem Solver:
  • 11 Answers
Try admin as both the username and the password, if this does not work then you need to reset the router by pressing the little button on the back of it.
Posted on Mar 28, 2011
I cant connect to my router but i have the password and i dont know what i must to do?
hook a cable to port 1 and then to your computer.
open web browser and enter http://192.168.1.1
enter user info into the popup box and configure.
Jan 28, 2014 | ASUS DSL-N10 Wireless-N ADSL Modem Router
How to get user name/password for router
"The default log-in credentials for de Web Config Interface are "admin" for the username and the password you create the first time around. As with all routers, you can always restore it to default factory settings via the recessed reset button on its back."
Jan 08, 2014 | ASUS RT-AC68U Dual-band Wireless-AC1900...
Asus wireless router password change solusion
connect to your router via ethernet cable and open your web browser. In the address bar type 192.168.1.1 which should bring up the router settings page. for user and password type in admin for both. Then navigate to the password settings and change it and save the changes.
Nov 09, 2012 | ASUS RTN10 wireless router
The gui setup wizard is not popping up/opening and i cannot access www.asusrouter.com
If you're using Windows, plug the ASUS device in via wired (ethernet). Hit Start, then type in CMD, then type in ipconfig. Look for wired local area connection. Do you see 10.0.1.1? That's probably the ASUS. Now, type that in your browser. Voila, the GUI should pop up. It worked for me.
Oct 10, 2012 | ASUS EA-N66 Dual-Band Wireless-N900...
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I can't log in to my router's web interface. I've tried the password as both admin and leaving it blank while the username is admin. The IP adress I'm using is192.168.1.1 and the ASUS router model is...
if you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
Jan 04, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Hello can u help me with the default user and password for an ASSUS router? i lost the old user manual and i reset it to default and i forgot the default user and password to set it. thx
Connect youra router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 04, 2010 | Gateway Computers & Internet
How to set up a password on ASUS RT-G32 wireless router so others cannot access my internet services.
Open a browser. Type in the router IP 192.168.1.1. Login to the router using your user id and password. If you have never set up a user id or password, then use the factory default ones to access. Once into the router settings, change the admin password to avoid anyone later accessing the router and changing your settings. Once you save the admin password change, you will be kicked out and must login again with the new password. Once in, go to wireless settings. Here you will able to set a wireless password (security key) for your wireless LAN. Once you save and exit, you will need to go to all your wireless devices and modify them with the security key in order for them to access the network. Once the key is in the router, your network is secure from outsiders getting in without knowing the key.
Aug 23, 2010 | ASUS Computers & Internet
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
I've lost the utility cd for installing a asus wl-520gc
you can setup your device using it's web user interface.
just open a web browser and type http://192.168.1.1. it'll prompt you for a username and password, type "admin" on both fields and it'll prompt you a web page where you can setup your internet settings and your wireless settings
(Note: your computer should be hardwired to device while doing the setps above)
hope this'll help you.
ciao!
Jun 08, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS (wl500g) Wireless Router Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
