Question about Bosch Washing Machines
I have a 5 year old Bosch Maxx 1000 washing machine. The "quick wash" function has suddenly stopped working even though the light is on. Wash programs now take around 2 hours each time
    Brigadier General:
  • 3,513 Answers
Hi
Wash program taking 2 hrs to complete is a natural thing. However it seems the quick wash function is not operating. If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly. Also try to reset your machine by unplugging it and then wait for half an hour and replug it and start the machine. If the problem persists it is suggested to call the customer care for a thorough check up. Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 28, 2011
Bosch maxx 1000
The fill valve may be clogged or defective
Oct 14, 2017 | Bosch Washing Machines
Bosch maxx wfl 1200
It is likely to be suffering from old age.
Nov 20, 2017 | Washing Machines
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
Bosch Maxx 1000 front loader starts but stops mid-cycle. End light flashes. Can't get any response from the machine until power is removed either through 'off' on rotary dial or the power outlet. I have...
Have one of these machines and when on the drying cycle the drum started pushing the machine around the kitchen and making a very bad sound so we stopped it before it blew up. On looking at the internal workings we can see a screw and part of the plastic housing that held it in place fell to the floor. It appears to be part of a frame that holds a metal brace in place that holds the drum in place and ensure that it joins the door to the machine. To me it looks as thought the machie is capable of washing but if we use it to dry it will damage itself and breakdown. Anyone else had this problem and any solutions.
Nov 13, 2009 | Bosch Washing Machines
Maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Sep 14, 2009 | Bosch Washing Machines
Bosch Maxx (ref WFL 2450). stopped during wash and switch on
Remove the front lower panel, screws underneath. Drain off water. Be prepared for more water. Check filter for clogging. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 01, 2009 | Bosch Washing Machines
Bosch maxx 2860 won't do a quick wash anymore
The timer sticks at one place.
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
Mar 20, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
